Turn Signals in 50 F1
Old 06-08-2015, 09:49 AM
1950FordF1's Avatar
1950FordF1
1950FordF1 is offline
Trying to work through incorpating an 1157 bulb into the front lamp holders to enable a dual filament bulb for turn signals.
Anyone with experience modifying the housing to recieve an 1157 bulb?
Old 06-08-2015, 10:02 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Here's one way: https://www.ford-trucks.com/forums/1...hn-morton.html
Usually you can just take a dual-filament socket (with the slots for the 1157 indexed tabs) out of some other light and slide it right in place of the original, and solder it in place.
Old 06-08-2015, 10:27 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
The process is one of the easiest - just remove the original sockets (push them out the back of the housing) and replace with prewired sockets available from most any auto parts store. The 48-50 parking light housings are very accommodating.
Old 06-08-2015, 10:58 AM
Mixer man's Avatar
Mixer man
Mixer man is offline
Reading my mind. I want to do the same thing. I bought a couple of taillight sockets from D.C. to do that. Figured I'd have to solder them in.
Old 06-08-2015, 01:14 PM
1950FordF1's Avatar
1950FordF1
OK. Ordered a pair from Napa, will post the part # when they come in (and work).
Old 06-08-2015, 04:40 PM
3twinridges's Avatar
3twinridges
3twinridges is offline
I have been thinking of doing the same with mine. Are you guys running the turn signals on the original 6 volt? What did you do in the back?
Old 06-08-2015, 05:38 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
I put double filament bulbs in my park lights to use as turn signals and LED lights in the back. It's a 6 volt system.
Old 06-08-2015, 05:47 PM
3twinridges
What would have been the original brand of turn signal housing that mounts on the steering column? Is there a yellow LED option for the front?
Old 06-08-2015, 05:52 PM
Jolly Roger Joe
I believe SignalStat was the original.
You can get different colored LEDs, white and red for certain. I'm not sure about amber. I just used amber lenses.
But depending on what you have in the circuit, you might have to use an LED flasher. I don't need one because I have a combination of LEDs and filament bulbs. The standard flasher requires resistance from the filament bulbs to work properly. LEDs don't provide that resistance.
Old 06-08-2015, 06:23 PM
pbsdaddy's Avatar
pbsdaddy
pbsdaddy is offline
Old 06-08-2015, 07:03 PM
1950FordF1's Avatar
1950FordF1
I have upgraded to 12. I eliminated the toggle switched for the dash lights and added a toggle for my turn signals. I'm going with 1157a bulbs in front and will look for two original tail light housings for the rear. Maybe in the future I will add h4 headlights and LEDs.
Old 06-08-2015, 09:58 PM
Mixer man's Avatar
Mixer man
There was a device offered awhile back that just flashed your parking lights. No need to upgrade bulbs, just install a brighter bulb. It was a complete kit. I wish I could find that again.
Old 06-09-2015, 12:13 AM
1oldtimer's Avatar
1oldtimer
1oldtimer is offline
Store - Store - Turn Signal - Classic Haulers F-1 Parts
I used the same version from mid fifty
Old 06-09-2015, 05:55 PM
1950FordF1's Avatar
1950FordF1
LS-6538 sockets from Napa are about .030 smaller than the original. Close enough though, I bent the flange in and TIG welded the new sockets into the F1 housings.
Old 06-09-2015, 06:12 PM
old_dan's Avatar
old_dan
old_dan is offline
If you're working on the fronts, I couldn't fit an 1157 bulb inside of the stock parking light lenses. I had to use a smaller bulb with a standard base. I ended up buying the amber small size bulbs from a motorcycle website.
Dan
Quick Reply: Turn Signals in 50 F1
