replacing thermostat housing
Old Jul 29, 2003 | 11:30 AM
ssaroff's Avatar
ssaroff
On my 1994 f-150 4.9/6 I replaced the thermostat and tourqued the housing too much and broke it.
I am trying to replace it now, but have the following problem:
the hose that goes to the heater has a metal connection which looks like it houses a sending unit (or is it a valve, dont know...), but that metal connection is at an angle.
I can not get the metal connection to tighten so that it is straight up, in other words, it ends up either lose and leaks, or tight and at an angle so I can not get the thermostat housing in place.
Anyone have any suggestions or a simple, "you do it this way?"
Much obliged.
Old Jul 29, 2003 | 09:57 PM
javi2001's Avatar
javi2001
There is a big house going to radiator, and a 1/2 inc hose going to A/C heater. There is also a Temperature sender installed on a 3/8NPT port wich is used by computer to know engine temp.
I'm not sure, but I gues your problem is on heater hose, isn't it? Using a very long screw driver or nut driver is the best way to get the hose clamp tight. You can tight before install housing on place.
Regards;
skeneguy
26
Mar 28, 2012 06:24 PM
82inline6
Aug 3, 2011 10:24 PM
El_Rodney
Mar 18, 2010 01:01 PM
Supercab
27
Aug 5, 2007 09:08 AM
grimace71
May 9, 2007 09:45 PM
