So I had my oil cooler done and egr delete put in. Why are my oil and coolant stuck a wide variance. It's at upwards of a 13 degrees difference between the two. Any further suggestions?
Recheck temps after an overnight "cold soak" to check for sensor/display accuracy. Should be within a degree or two from each other. If they're off add difference to hot numbers for a more accurite idea of where you're at. There is a bypass valve in the oil cooler housing that can stick open and allow oil to pass through the cooler too fast for proper heat transfer. A thorough cooling system flush is required to keep the new cooler from clogging quickly after replacement.
For those of us that have no EGR cooler, you will see a wider difference between oil and coolant. 13 is nothing to worry about but did not understand your torque reference, you spike a short time under load (trailer) or normal driving?
It's just a random snap from whatever its reading. Say like 191* like earlier. Then it will snap to 32* then right back to 191* what kinds of differences will I see between without the egr cooler? I'm just wanting to know what is safe and what's not.
