Mine started acting up last night on the way home from the races. It went to shift into 4th and just went right back to 3rd. OD light flashed so i pulled the codes, one was PO733 the other tranny code was 3-4 shift failure(cant remember code). Fluid smells burnt, so I know its time to rebuild, truck has 149k and I tow with it all the time. Tranny has a vavle body, not sure what brand was in the truck when i got it.
Suggestion on torque converter, and upgraded hard parts, the guy that is doing the build said it needs a shift solnoid pack upgrade, and that it probaly broke a snap ring that is prone to fail and that they make a redesign/upgrade for it.
My truck is a tow rig, only runs on 60hp tow and 80E.
