Ashtray part wanted
Old Jun 2, 2015 | 05:24 PM
orich's Avatar
orich
Just a heads up.
A1967 ash tray will not fit into the 68-72 inner guild bracket all the way since the 67
tray door is at a different angle and will hang outward about haft way not closing up flush to the dash.
I don't know if just the roller bracket would work or not tho.
Orich
Old Jun 3, 2015 | 03:06 AM
hot-rod's Avatar
hot-rod
Hi Orich,
thanks for this information
@TeachNlive4ever,
dont stress
Old Jun 3, 2015 | 08:10 AM
TeachNlive4ever's Avatar
TeachNlive4ever
Hot-Rod
I found your bracket and bearings. I had collected this ashtray back in 1985 so the bottom of the tray is "not so pretty good".
PM me where to send it
The only time i stress is when it won't fire off.
If it has girl parts or tires, its gonna give you problems...
Old Jun 3, 2015 | 10:47 AM
Gembone's Avatar
Gembone
Since this topic is about the bearing slide for the ashtray I thought I would ask, what grease do you guys use for your slides?
Old Jun 3, 2015 | 11:25 AM
orich's Avatar
orich
I use a light coat of the heavy white grease same as used on the brake backing plates shoe resting pads. & star adjusters threads.
I use to use paraffin base wax tho.
Orich
Old Jun 3, 2015 | 11:47 AM
Coastal68's Avatar
Coastal68
I got tired of the fingernails-on-chalkboard sound so I took a dab of high temp bearing grease and pushed it into the grooves. Problem solved.
Old Jun 3, 2015 | 12:21 PM
qman's Avatar
qman
I use Remoil.
Old Jun 3, 2015 | 06:39 PM
JEFFFAFA's Avatar
JEFFFAFA
I use white lithium grease spray.
Old Aug 24, 2015 | 05:45 PM
hot-rod's Avatar
hot-rod
I am still looking
Old Aug 24, 2015 | 06:31 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by hot-rod
I am still looking
I might have one that would need to be sanded and painted. That good enough?
Old Sep 4, 2015 | 04:36 AM
hot-rod's Avatar
hot-rod
Hi JEFFFAFA,
that iss good enough, because i need only this part
Old Sep 4, 2015 | 02:31 PM
mrcman58's Avatar
mrcman58
I dont want to step on anyones sale, but i can help with the bracket and roller ***** if you cant find them anywhere else i have about 15+ ashtrays that fit the 68 to 72 most of them have the factory colors, the 67 ashtray was totally different but i have those also.
Old Sep 4, 2015 | 03:09 PM
  #28
JEFFFAFA's Avatar
JEFFFAFA
Hi JEFFFAFA,
Sorry. I checked but my extra ash tray is gone. No where in my parts stash boxes. I prolly gave it to another FTEer.
Old Sep 4, 2015 | 03:42 PM
  #29
D & D's Avatar
D & D
I am pretty sure that I have one. I will check when I get home in a couple of hours and let you know. I remember reading this thread when it first started, visited a JY for other parts and got the ashtray because it was fresh on my mind.
Old Sep 4, 2015 | 05:08 PM
  #30
qman's Avatar
qman
I doubt you'd be stepping on anyone's toes. Poor dude asked back in May and still don't have them.
Maybe it's cuz he's in Germany.
Don't you guys have junk yards over in germany?
