Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Help
Old May 29, 2015 | 11:49 PM
airborne0130's Avatar
airborne0130
Help
I'm trying to figure out if my fuel pump is bad at a idle I'm get almost 32 pounds wot I'm get 35-36 pounds ... I've changed plugs wires idle air control valve .. Timing is on, it's bogging down , it was back firing a spitting . Found a kinked line fixed that but didn't solve problem... Pulled rear fuel pump no trash in pick up screen... No matter what tank I run it runs the same... Test fuel pressure regulator it's good when I unplug it fuel pressure jumps to 40... Truck does not have catalytic converter. I'm really stumped at what it could be . The best I can describe it is it's like someone is holding my back as I'm trying to go forward. Any and all help us appreciated
Old May 30, 2015 | 01:32 AM
85e150's Avatar
85e150
Is this regarding your 2008 f 250? If so you are in the wrong forum.
Old May 30, 2015 | 08:07 AM
airborne0130
No this is on my 94 f350 with a 7.5 460
Old May 30, 2015 | 01:58 PM
85e150's Avatar
85e150
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
airborne0130
May 29, 2015 09:25 PM
armydad71
Mar 16, 2010 10:24 AM
fordman 460
Jan 7, 2009 05:25 PM
switzee
Bronco II
Aug 23, 2005 04:11 PM
