Sponsored by: Real Truck
V10 belts
Old May 29, 2015 | 06:55 PM
Dirthog53's Avatar
Dirthog53
Angry V10 belts
Having a problem finding the right belt diagrams for a 2000 F53 stripped chassis in a motor home and the dealer has been no help even after spending a bunch on parts
Old May 29, 2015 | 08:50 PM
dkf's Avatar
dkf
See if your pullies and accessories are in the same the location as this diagram.
http://www.frontiernet.net/~jcray/04...eltDiagram.jpg
Old May 30, 2015 | 05:19 AM
Dirthog53's Avatar
Dirthog53
Thanks, That is close the only thin mine has another idler pulley between generator and power steering pump not sure that matters cause it would be riding against the outside of the belt.
Old May 30, 2015 | 09:00 AM
asdrew's Avatar
asdrew
I had the same issue with a 2000 E350 church bus with V10 some years ago.
The belt broke on the road and I found that is was not the same size even, nevermind the Ford factory belt routing that was on the engine compartment label. The problem is that once it is sent out to the motorhome manufacturer, the belt components and routing are almost always modified.
I ended up reasoning it out myself and then drawing up and laminating a new belt diagram and putting it in the engine compartment. It seems this was a major oversight of the bus manufacturer, but of course their main emphasis is just to sell a new bus.
Old May 30, 2015 | 05:16 PM
Dirthog53's Avatar
Dirthog53
Think I have it figured out only thing is the temp. still seems to start and climb on the hills didn't go into the red today when I got it back together. went up over 1/2 way on the gauge going up hill and not a very long hill even coming up my drive way. Then I stalled it with the brakes and trans and it climbed right up almost to the red. This is after replacing the water pump, fan clutch, belt, adjuster and the thermostat and a new sender.
bbacon
Sep 27, 2014 02:40 PM
green250
Modular V10 (6.8l)
Feb 14, 2013 09:16 AM
vee10td
Modular V10 (6.8l)
Jan 10, 2011 10:45 AM
caprang
Apr 10, 2009 07:16 PM
Pastmaster
Jun 5, 2002 11:37 AM
