4 threads per spark plug hole pic
Old May 26, 2015 | 05:53 PM
Snowseeker's Avatar
Snowseeker
4 Threads per cylinder.
Old May 28, 2015 | 02:01 AM
Stewart_H's Avatar
Stewart_H
The above post was cut from its original thread and then edited to show only the above pic in order to create a separate thread to be saved in the tech folder sticky.
Stewart
Old May 28, 2015 | 02:06 AM
Stewart_H's Avatar
Stewart_H
Link placed in the tech folder sticky in the General Engine & Engine Compartment Threads section.
Stewart
Old May 28, 2015 | 03:36 AM
Bently_Coop's Avatar
Bently_Coop
Thanks stewart and snowman. Will be a great reference for new V10 owners
Old May 28, 2015 | 07:31 AM
Snowseeker's Avatar
Snowseeker
Once I get the inserts I will get more pics of the whole deal and fix as well.
Old May 28, 2015 | 12:07 PM
BEARDOWN's Avatar
BEARDOWN
Do you know the build date of that motor
Old May 28, 2015 | 12:15 PM
Apocalypse's Avatar
Apocalypse
Stop editing things Stewart! Now I'll never get to see what it looked like pre-Stewart!
Old May 28, 2015 | 02:57 PM
Stewart_H's Avatar
Stewart_H
Why not? Your finger too tired to go click on the original thread where the post was pulled from?
Stewart
Old May 28, 2015 | 07:40 PM
Snowseeker's Avatar
Snowseeker
I will have to look. The Excursion it came out of is a 2000.
I got a reply from a seller on amazon that the time sert 51459 inserts have 5 threads on the inside (plug side) of the inserts.
Anyone have a part number or idea for an insert with more threads?
Old May 28, 2015 | 08:39 PM
Snowseeker's Avatar
Snowseeker
Found this link. + TIME-SERT FORD SPARK PLUG REPAIR blown out spark plugs problems blowout Frequently Asked Questions spark plug thread repair+
Whats the deal with the "long thread" plugs? Can those be used in the triton with the right insert?
Old May 28, 2015 | 11:22 PM
Apocalypse's Avatar
Apocalypse
Stewart
Didn't realize I could go look if I wanted to... I don't want to now though, the moment is ruined. Thanks Stewart
Old May 29, 2015 | 04:32 AM
Stewart_H's Avatar
Stewart_H
That tells me you pulled a Stewart and did a speed read and missed important info!
Second post...
Stewart
Stewart
Old May 30, 2015 | 04:05 PM
AppocAlexx's Avatar
AppocAlexx
Im doing this same repair this week and am getting the motorcraft SP-479 spark plugs the ones made for the 6.8L. I was wondering if i should get longer threaded spark plugs as well.
so im following this post and will post if i find anything out about this.
Old May 30, 2015 | 10:00 PM
Snowseeker's Avatar
Snowseeker
I did notice today the aftermarket plugs that were in the motor are threaded the whole length of the shaft up to the taper unlike the stock plugs. If I could find just a taper timesert with full threads I would go that route.
Old May 31, 2015 | 07:20 PM
AppocAlexx's Avatar
AppocAlexx
I thought these inserts are supposed to be stronger and will be able to hold the stock spark plug with no problems, and the full threaded inserts are only for curtain heads, the only thing I could see doing is the longer threaded spark plugs and adding full threaded inserts will cause the spark plug to sit deeper into the cylinder chamber possibly hitting the piston head, Im kinda confused about the whole longer thread thing I guess. Iv been reading too much on this topic over the past few days and am about to just throw the inserts in there and hope things work out.
