EFI FE stuff
Old May 28, 2015 | 01:39 AM
UNTAMND's Avatar
UNTAMND
EFI FE stuff
I searched and am still reading.
Do you guys have any interesting sites to do with efi on an FE?
Old May 28, 2015 | 05:45 AM
jowilker's Avatar
jowilker
Since the FE was dropped in 76, and there are so many better engines out now for EFI there just isn't a lot of demand for the 40 year old engines.
My 2
John
Old May 28, 2015 | 10:21 AM
UNTAMND's Avatar
UNTAMND
While I agree with you 99%, there's always this one percent part of me that loves the FE.
I could have put a different engine in my 67 mustang, but I wanted an FE. I found a 428cj and built it. It's fun. But I'm a mix between old school and new. I would love to blend the two technologies together. I have made an adaptor to put a 460 e4od behind the FE, but it's computer controlled. They make a couple real nice trans controllers, I've used them before, but now I want efi on the engine. I've put megasquirt on about 10 cars from the 60s to the early 2000s. I just wanted some ideas of others here.
Old May 28, 2015 | 11:16 AM
69cj's Avatar
69cj
Holley and Fast make square bore injection systems that will work on fe's.
Old May 28, 2015 | 12:29 PM
UNTAMND's Avatar
UNTAMND
They don't integrate with trans. They are also a little pricier than I want. There are plenty of aftermarket efi options, just none I really liked. I've used accel, edelbrock and motec, and they work fine. I just wanted something different.
I'm modifying a sbf distributor to work in the FE engine. After that it should be pretty easy to put ford efi on the engine and have it to control the transmission as designed.
Old May 29, 2015 | 05:32 AM
jowilker's Avatar
jowilker
Step out on a new limb, find a new wrecked F150 and go with a EcoBoost setup.
Might be a fun project.
John
Old May 29, 2015 | 08:25 AM
UNTAMND's Avatar
UNTAMND
I have an original 67 mustang s-code fastback... I get enough crap when people find out I put a 428cj in the car!
I would love to build an ecoboost classic though. I bet it would be fun. I have plenty more cars to do it with, just need the funds.
Old Jun 1, 2015 | 04:59 AM
jowilker's Avatar
jowilker
I promise that crowd don't hang at the Fs like the Stang.
Hey you can always leave the hood down.
John
Old Jun 1, 2015 | 09:09 AM
MIKES 68 F100's Avatar
MIKES 68 F100
try doing a search , I could have sworn there was a thread on here about someone using a Dodge fuel injection on a FE
Old Jun 1, 2015 | 10:54 AM
69cj's Avatar
69cj
And how would they know without someone telling them? lol
Old Jun 1, 2015 | 11:11 AM
UNTAMND's Avatar
UNTAMND
People like ourselves are quite observant... Like seeing 4 bolts per exhaust port, and the hatchet behind the balancer...
And the valve covers that say 428.
Old Jun 2, 2015 | 01:15 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
How about we all stop telling this guy how to NOT do what he really wants to?
Are there any Ford 460-based E4OD throttle-body injection systems out there? (I already know the answer) -
Old Jun 3, 2015 | 11:55 AM
UNTAMND's Avatar
UNTAMND
I don't believe ford ever put tbi on a 460. I think the very rare 460 grand marquis had a carb. It wasn't overdrive anyway, so using really antique efi isn't on my list.
I was thinking about using a tripower intake with the ford Holley bolt pattern carb base tbi at one time, and use megasquirt, but the tripower intakes are pricy. Or if I could find a different dual quad, where I could use two gm tbi with an adaptor.
If I buy an intake to put fuel injector bungs in, I'll use some stock efi setup. Either 460 truck, with e4od, and get quarterhorse to tune it, or I'll go nuts, retrofit a crank trigger and use obd2 setup from explorer and a 4r70. We will see I guess.
Old Jun 3, 2015 | 04:33 PM
jowilker's Avatar
jowilker
OK then whey are you trying to move him to another street, he asked about a FE and you are trying to feed him 460.
Last I heard 385s & FEs had different daddys.
John
Old Jun 3, 2015 | 06:09 PM
scskysc's Avatar
scskysc
This is on my to-do list also.
I have a good amount of experience tuning GM ECU's both in vehicle specific and the GMPP kits, but newer GM ECU's are probably a lot more complex system than is needed for the FE Motor.
All things being equal I really don't see a downside to the Edelbrock E-street EFI System other than there being no ignition component at that price.
Going the DIY route is probably as expensive as getting the turn-key kit from Edelbrock, but DIY will still require tuning that inevitably will end up being done by an experienced tuner for an additional cost.
I have EFILive for GM tuning and lots of experience with tuning newer GM E67/38 ECU's.
My dream goal is to use a newer GM ECU and do a full conversion including Coil On Plug, but I suspect that it will get executed with an old GM PCM and Throttle Body Injection only.
-Adam
1970 Ford F-250 Camper/Explorer Special
