Which Radiator to buy?!!? Overheating Problems
ok im having overheating issues with my 79 f150. it has a 1982 302 in it. the problem is there is this red sediment rust colored stuff all in the radiator and i cant get it out. i have flushed it several times, even taking it out of the truck once to flush, ive ran cleaner through it and it still hasnt fixed the problem, it runs fine at speeds up to 50, but once i get on the hwy and go 60+ the temp gauge creeps up until the point of boiling out .. At first i thought i had got the sediment out and believed it to be a thermostat issue so i replaced it with a 195F thermostat and it has not fixed the problem? Next solution is replacing the radiator but there are so many i do not have a clue which one to buy, any suggestions? has anyone else had this issue??
I think you are on the right track... hot at speed usually means the radiator is not effective enough.
I ran a parts store "3 core high capacity" unit for a while to replace the 35 YO original (78 400M). After a year or two, I had some "temp creep" in hot weather pulling hard. Not boiling but did not care for it. I changed to a Champion "4 core" and problem solved. Maybe a bit overkill but that is OK.
The Champion seems like a good product at reasonable price. Probably 3 core would be fine with a 302.
For the rust, suggest you pressure flush before installing a new rad. You can buy or make a setup that uses a garden hose and compressed air to really clean the cooling system. Fill it with water and hit the air to blast out dirt. Air pressure needs controlled to avoid damage.
Flush and fresh anti freeze should keep it clean.
sounds like the champion 4 core is the overkill to go. i also bought back flush kit the other day and plan to flush the system before installing new rad. Also water pump is working i believe? i dont know how to really test it or see if its working properlly. hopefully the new flush along with new t-stat and radiator will solve probem. any more thoughts? i will keep updated
For the flush, best to ignore the radiator since you are changing it anyhow. I like to remove the T stat then re-install the housing (no gasket needed). Hook up the top hose and adapt your flush kit to the top hose. 1 1/4" or 1 1/2" pipe usually works... PVC is fine. Clamp the top hose end to the adapter then turn the hose on. Let it run out the lower WP connection. When the block is full of water, hit the air to blast out the crud. Repeat several times until it runs clean.
Best to clean it when you are almost ready to put it back together so it does not sit too long without corrosion protection in the coolant.
My flush setup is home made but here is a ready made one for reference.
Save on OTC Tools 6043 at ToolTopia.com
