Repair List
Old May 27, 2015 | 09:02 PM
98Econoline150's Avatar
98Econoline150
Repair List
I'm back and I thought I'd share the repairs we are making to our van. It is a work in progress, I have been raiding the junkyard and "Vintage" parts from Ford.
01. Repair damage to body from road salt -nasty
02. Repaint the body with Toreador Red Metallic - too many rock chips, and parking lot dings
03. Repair and repaint with copper metallic, the running boards chipped and scuffed
04. Replace Cowl Vent Screen and seal - sun rotted
05. Install new Mark III LXO Stripe Kit - faded and old
06. Replace Front and Rear bumpers - dented metal and scratched trim
07. Replace windshield and molding - windshield chipped, molding lifting and cracked
08. Replace Cargo Door Window Bolts - rusting
09. Replace Parking Brake Cable - frozen
10. Repair Emergency Air compressor - no air flow
11. Replace Rear Air Conditioning Lines - rusted
12. Replace Rear Heater tubes and hoses -rusted
13. Repair Rear blower motor - intermittent operation
14. Repair Mood Lighting -some working some not
15. Replace Leaf Springs - sagging COMPLETED
16. Replace Ball Joints - steering slop COMPLETED
17. Replace EGR System - threw code COMPLETED
18. Replace Wheel Speed Sensor, Left - rusted out COMPLETED
19. Replace Wheel Speed Sensor, Right - threw code COMPLETED
20. Replace ABS Control Module - ABS misfire diagnosed by Ford COMPLETED
21. Replace Wheel Bearing - ruined by ball joint installation COMPLETED
22. Replace Front Brakes - poorly installed by Ford COMPLETED
23. Install new rotor shields -missing
24. Alignment - overdue COMPLETED
25. Tire Rotation - overdue COMPLETED
26. Replace Wheel Speed Sensor Bolts - broken
27. Brake Flush - overdue COMPLETED
28. Transmission Flush - overdue COMPLETED
29. Replace Driver Door hinges - worn out
30. Replace full exhaust system - hack job rotted out
31. Install New tires COMPLETED
32. Install Ford Wheels COMPLETED
33. Replace Front Blower Motor - poor quality repair COMPLETED
34. Replace Front Door Weatherstripping - worn out COMPLETED
35. Replace Rear Door Weatherstripping - worn out
36. Repair Leaking Evaporative Emissions System - threw code COMPLETED
Got a spare grille from the junkyard, these are all parts I have collected and assembled myself. I painted the grille myself aswell.
Old May 27, 2015 | 09:17 PM
98Econoline150
We purchased new tires and were initially going to keep the "Z Racing" wheels on there. We somehow ran over a nail or a screw which ruined one tire so when the replacement tire came we decided that we wanted to go with original type Ford 9-Spoke wheels. My father and I decided that they were too far gone. We ordered 4 from RockAuto and when they came we changed each tire individually and then balanced it (one per day). The spare tire was also changed and the wheel color matched.
Old May 27, 2015 | 11:49 PM
econolinemanor's Avatar
econolinemanor
Glad to see another Conversion Van being saved!
Old May 28, 2015 | 02:32 PM
98Econoline150
Front Brakes 5-Lug with 4WABS
REQUIRED TOOLS
Large Channel Locks
Small Channel Locks
L Shaped Pick
Medium C-Clamp
13mm Ratcheting Wrench
13mm Socket 3/8" Drive
3/8" Torque Wrench
1/2" Breaker Bar
1/2" Torque Wrench
1/2" Extension
13/16" Socket 1/2" Drive
3/8" to 1/2" Converter
1 1/16" Socket 1/2" Drive
Length of wire or a coat hanger
REQUIRED PARTS
Brake Rotor and Hub YC2Z-1V102-FA x2 Motorcraft
Wheel Seal BRS-9 x2 Motorcraft
Inner Wheel Bearing SET13 x2 Timken
Outer Wheel Bearing SET12F x2 Timken
Washer E7TZ-1195-A x2 Motorcraft
Nut 374504-S100 x2 Motorcraft
Nut 390622-S x2 Motorcraft
Cotter Pin 1/8" x 2" x2 Everbilt
Super Duty Pads 2U2Z-2V001-AJ x1 Motorcraft
Hardware Kit 1L3J-2C535-CA x1 Motorcraft
OPTIONAL PARTS
Grease Cap 618503 x2 Dorman
Not all tools pictured
Old May 28, 2015 | 06:03 PM
econolinemanor
I think those Motorcraft SuperDuty Pads and Rotors were the same numbers I put on my 02, best money I ever spent! No noise or squeal......smooth as silk.
Old May 29, 2015 | 08:50 PM
98Econoline150
How to Replace Front Door Speakers
Old May 31, 2015 | 07:32 PM
98Econoline150
I have picked up a set of front doors to replace the original doors, I will take some pics when I am done stripping them down to the shells.
Old Jul 26, 2015 | 12:26 AM
98Econoline150
Here is the new bumper ready to go on. Just waiting for the weekend to be over to order parts from Ford. Should have the bumper back on about Thursday.
Old Jul 26, 2015 | 07:19 AM
Im50fast's Avatar
Im50fast
What's ABS misfire?
Old Jul 28, 2015 | 08:07 PM
98Econoline150
Old Aug 2, 2015 | 12:55 PM
98Econoline150
The front end is done.
The interior is next. This includes reinstituting the rear air, and returning the van to a more stock interior. The conversion was sweet in 1998, but the electronics are all shoddy and old now. The old broadcast TV and dinosaur VHS player have been removed. An updated console has been installed, and the front seats are next.
Dan F-6
78
Oct 9, 2019 09:24 AM
pitpawten
Nov 19, 2015 04:20 AM
run6.0run
Oct 25, 2012 02:47 PM
clhart426
Mar 7, 2012 06:31 AM
OGTerror
Offroad & 4x4
Jan 14, 2010 06:00 AM
