Broke the rear spring
Old May 27, 2015 | 03:54 PM
PStruwing's Avatar
PStruwing
Hello All
I managed to break one of the leaf springs in the rear passenger side of my 97 E-150 conversion van. I will troll the scrap yards to see what is available....but I want to keep the nice smooth ride.
Any suggestions? Yes I will stop off roading...
Cheers
Old May 27, 2015 | 09:56 PM
98Econoline150's Avatar
98Econoline150
Go to your local Ford dealer and ask the parts guys where they get springs from. I did and they told me. I got a great deal, since if you order springs through the dealer they sub it out and charge you double plus install.
Old May 27, 2015 | 11:55 PM
econolinemanor's Avatar
econolinemanor
One of the Site Vendors is ATS Springs.........I'm sure they would set you up!
Old May 28, 2015 | 12:12 AM
68Mercury250Ranger's Avatar
68Mercury250Ranger
don't stick a used leaf spring in it. go to your local spring shop and get them to replace the broken leaf and the matching one on the opposite side. or buy the leafs/ubolts/centre bolts yourself if you are up to the DIY.
I was over to Madoc on sunday from the wingham area along secondary roads about 4.5hrs each way and some of them are just horrible, my trailer had the R side airborne a few times when it was empty. you don't need to be offroading the winter was hard on the roads!!!!!! knocked the bearing cap off the R rear wheel somewhere along that road, noticed it gone when we stopped in Orangeville on the way home.
I'd still rather drive those than the 400 series highways.
Old May 28, 2015 | 06:48 AM
PStruwing's Avatar
PStruwing
I visited ATS and they have great deals, if I was in the USA.
ATS has 2 grades, normal and heavy duty. I am assuming I was heavy duty due to the added height of the roof being a high top van.
Old May 28, 2015 | 06:49 AM
PStruwing's Avatar
PStruwing
I travel those road quite a bit but I am sure I broke the spring when camping with Scouts and drove way to far into the woods fully loaded with kids and gear!
Old May 28, 2015 | 06:53 AM
JWA's Avatar
JWA
Please don't take this as bashing but does this off-roading and possibly over-loading that E150 chassis bear on this breakage?
Either way if this is a common hauler for your Scout trips I'd buy and have installed only new slightly heavier duty rear springs. Adding to existing high mileage springs won't serve you well over time.
Better to spend a few bucks up front to avoid down time at the most inconvenient of times.
Old May 28, 2015 | 07:46 AM
PStruwing's Avatar
PStruwing
[QUOTE=JWA;15390214]Please don't take this as bashing but does this off-roading and possibly over-loading that E150 chassis bear on this breakage?
ABSOLUTELY! Yes it does! As for bashing I am fully responsible so load it on...get it...load it on! Never mind.
Old May 28, 2015 | 08:08 AM
JWA's Avatar
JWA
[QUOTE=PStruwing;15390319]
Things happen----lessons learned are the most valuable parts of such things right?
Check with ATS Junior here---he's a sponsor and have always seemed eager to help us here on FTE.
Old Jun 1, 2015 | 06:17 PM
DHuskic's Avatar
DHuskic
Hey, I had the same thing happen to me today. The leaf just rusted out and snapped when I was going over railroad tracks today. Right at the end where it meets the mount on the frame.
Old Jun 1, 2015 | 08:16 PM
PStruwing's Avatar
PStruwing
Wow! Do we have a theme going here?
Old Jun 1, 2015 | 11:28 PM
68Mercury250Ranger
I'll try and break some on my E350 but the load on my trailer Tuesday will only be a little Kubota lawn tractor so it might be tough. I haven't broke any yet but I sure deserve points for trying on the stock springs!
Old Jun 12, 2015 | 02:33 AM
DHuskic's Avatar
DHuskic
Hey now, that's what 13 years of Michigan do to a van. Turns out I had my verbiage wrong. My driver's side rear leaf spring shackle broke. $20 part, but 6 some hours to get the rusty bolts out. Gonna go through and replace the remainder of the leaf spring suspension at the end of the month.
Old Jun 12, 2015 | 06:18 AM
PStruwing's Avatar
PStruwing
Something looks backwards here!
Old Jun 12, 2015 | 09:41 PM
68Mercury250Ranger
from Newmarket to Wingham , mostly highway 9 . dually is a 93 7.3 E4OD.
I had lots of traction, enough tongue weigh to take some weight off the steers..
who says you can't tow with an extended van
