Sponsored by: Real Truck
V10 Front Spring SURVEY
Old Jul 28, 2003 | 09:55 PM
SNEAKY F350's Avatar
SNEAKY F350
2003 F-350 XLT
Crew Cab/short bed
V10
FX4
4.30 gears
I'm trying to get a sense of who has which springs out there. I ordered the Heavy Service Suspension pkg but my VIN indicates that it is not present, and the door jam sticker indicates a GAWR of 4800 lb for the front springs. My dealer says that everything is correct according to what was ordered. I need some data to fire back. If you are a V10 guy, please look in your driver side door jam at the upper left hand corner of the sticker and post your front GAWR and a short description of how your truck is equipped. Your help will be greatly appreciated. Thanks a million.
Old Jul 29, 2003 | 08:10 AM
Habitat's Avatar
Habitat
Mine says 3,650. I bought it used so I couldn't be certian of any packages.
Old Jul 29, 2003 | 08:15 AM
rvrrat's Avatar
rvrrat
Mine states front GAWR=4670, my '01 F-250 Super Duty has heavy duty suspension towing package.
Old Jul 29, 2003 | 08:20 PM
99f350sd's Avatar
99f350sd
That package isn't the same as the plow package is it? Do a search on X springs and look at the chart I posted..
Old Jul 29, 2003 | 08:56 PM
tencylinders's Avatar
tencylinders
I currently own a 2002 V-10 CrewCab short box 4WD with Automatic. The front GAWR is 4800lbs according to my door sticker. The truck did come with the camper package ($160.00 option) however I do not think that affects the weight rating (not sure though).
Eric
Old Jul 29, 2003 | 09:06 PM
99f350sd's Avatar
99f350sd
lookie here
http://www.carnegiebody.com/pfffgawr.htm
Old Jul 29, 2003 | 09:30 PM
Outpost22's Avatar
Outpost22
Mine says 5200lbs. on the front
Old Jul 29, 2003 | 11:37 PM
HeavyAssault's Avatar
HeavyAssault
The only way to get the X-code springs are with the snow plow package. The others usually will only place the highest rate for the options that you choose. Go to EDMUNDS.com and price a new truck, load the options menu and there is a INFO link that will pull up a menu that explains the option that you have selected. Since your V10 is lighter than a diesel you will only get the lower rate springs. Understand?? Mine reads 4400 GAWR with the T springs. '99 F350 V10 CC SB 4x4
Old Jul 30, 2003 | 09:23 AM
Steelheader14's Avatar
Steelheader14
...mine came with a 4800lb front GAWR, and it does have the camper package. I think it would have been 4400 without.
It doesn't really matter, but I'm still not sure if it's a D50 or 60 axle.
Old Jul 30, 2003 | 10:01 AM
daimon1054's Avatar
daimon1054
3950 lb
2001 F250 Crew Cab
Tow package
Old Jul 30, 2003 | 04:55 PM
99f350sd's Avatar
99f350sd
I'm pretty sure most 2002's came with D60 or sometime that year.
Old Jul 30, 2003 | 04:57 PM
abendx's Avatar
abendx
mine say fabtech?
Old Jul 30, 2003 | 05:01 PM
Waxy's Avatar
Waxy
That doesn't say much for the company when the CAO doesn't use his own products.
Waxy
Old Jul 30, 2003 | 05:03 PM
RRMike's Avatar
RRMike
Steelheader,
Your front axle is a Dana 60.
Old Jul 30, 2003 | 05:13 PM
abendx's Avatar
abendx
waxy... he asked about springs..... i only get 8" of my height from springs (a hold over to the days before my *** got so big!).... now if he wanted to know how my lift went from a 'gay' 8 inchs to a ASSarific 25 inchs he would have the clear and proud response that it came vis chrome spray painted cardboard blocks made ASSpecially by *** products Inc. !
