New 5th wheel
#31
As mentioned earlier 5% or less with a good FICO score should be very easily obtainable. Have you tried a credit union? You could meet with a loan officer, run some numbers, get pre-qualified, then go find a vehicle that meets your needs. I personally would do without before paying 15%, but that's just my opinion.
Good Luck!!!
Good Luck!!!
#32
One thing that may also help with stability is I, after leveling front to rear crank rear scissors down to the wood pads I use under them and then lower the front until I can slide a 1X8 between rear jacks and blocks and then raise front back to level. That puts a little more weight on the jacks, most are rated for enough weight. Also use enough blocking to avoid extending rear jacks more than about 3/4 of their lift range, much more stable that way. I carry enough blocking that I can have a stack 8 to 10 inches tall if needed. Also I am pulling a 16K 5'er with an 18 foot boat behind it with a F350 6.0 and yes I have had a few problems with it. After bullet proofing, they can be very reliable and pull very well.
OJs DNA
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
12-16-2016 07:37 PM
Greywolf
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-04-2014 07:24 PM
FishOnTheBrain
09-06-2004 02:50 PM
mike73
06-11-2003 07:26 PM
