Sponsored by: Real Truck
Abs ??
Old Jul 28, 2003 | 07:12 PM
mdwallace's Avatar
mdwallace
Angry Abs ??
I have a 2000 F350 Super Duty, about one week ago I was slowing down for a stop light and the break pedal started moving and the breaks acted like they were being pumped. I know how the ABS system workes but this happened and still does on a nice warm day, no rain, snow, nothing, running about 4 miles per hour and not all the time. The breaks work fine at higher speeds and like I said this only happens at around 5 miles per hour or slower while pressing the break. Also the ABS light doesn't come on. Can someone please help me out. Also can any one tell me where the plug for a electronic break is located. I owned a 1997 F150 and it was located right under the steering wheel under the dash. I can't find this one anywhere!!! Thanks for any help you can give!!!!
Mark.
Old Jul 28, 2003 | 07:46 PM
99f350sd's Avatar
99f350sd
Abs ??
most likely you have a dirty or bad sensor on one of the front wheels..
Old Jul 29, 2003 | 10:44 AM
Shakeable's Avatar
Shakeable
Abs ??
Wouldn't a bad sensor be detected as not matching speed and throw an idiot light?
Old Jul 29, 2003 | 11:41 AM
99f350sd's Avatar
99f350sd
Abs ??
rear one would
Old Jul 29, 2003 | 01:06 PM
white99's Avatar
white99
Abs ??
The electric brake controller plug on my 250 is- take off the acess panel to the fuse box look up toward the radio and in a little hole you can see it attached to a support frame of the dash.
JimP
kyerstenaudrey
1978 - 1996 Big Bronco
Jul 16, 2013 02:25 PM
P-Bod
Jul 9, 2003 07:21 PM
