Starting down this road
Old May 22, 2015 | 10:39 AM
Haywire-Powerstroke's Avatar
Haywire-Powerstroke
So i was thinking of stage 1 injectors, 6637 intake, have a 3" downpipe and 4" exhuast but may upgrade to a 5", and then either upgrading the stock turbo or do you guys think i would need a different one alltogether? also some sort of an upgraded hpop. finally throw in a hydra 17 pos chip. is there anything else i would need to not brake things? and where would this put my truck in as far as power and drivability and towing?
Old May 22, 2015 | 11:27 AM
cowmilker08's Avatar
cowmilker08
Gauges (namely EGT)
Transmission if E4OD, or Clutch if ZF5
E-fuel (optional, but recommended)
You can run stage 1's with the stock turbo for a while, but your best bet would be an S366. That's a big project.
Old May 22, 2015 | 11:36 AM
Haywire-Powerstroke
Forgototo mention I do have gauges already and it's an e40d. What about one of the bigger drop in turbos? Or would that still not be enough
Old May 22, 2015 | 12:26 PM
cowmilker08
The bigger drop in turbos are barely better than stock. You could do a D66, but it doesn't have a good reputation in these parts.
Old May 22, 2015 | 12:35 PM
Haywire-Powerstroke
Whys that? Lots of problems with it?
Old May 22, 2015 | 12:44 PM
cowmilker08
It just not quite up to the challenge of Stage 1 injectors. One issue is high EGTs with D66 + stage 1 injectors.
I've never tried it though. I'm just summarizing what I've read here and a few other places.
Old May 22, 2015 | 12:45 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Marginal performance increase over the stock turbo
Old May 22, 2015 | 12:48 PM
Haywire-Powerstroke
So sounds like the s366 would be the best and only way to go really. That looks like a big project, course the whole thing is really haha
Old May 22, 2015 | 12:56 PM
cowmilker08
You could buy "complete" bolt on kits, but they are mucho $$$.
S366 isn't the only option, but by far the most popular these days.
When I first joined this site everyone was doing what was called the modded h2e turbo. Not sure why no one uses that anymore.
Some other guys were using HX60 turbos too I think.
Old May 22, 2015 | 02:10 PM
Haywire-Powerstroke
I'll have to look up some of those turbos and see what I can find. Any ideas on where this would put me in the horsepower range?
Old May 22, 2015 | 05:06 PM
Haywire-Powerstroke
Old May 22, 2015 | 08:51 PM
fordpride's Avatar
fordpride
The one big problem with the h2e is the hypermax kit. If down the road you decide to change the turbo you have to change everything as where with a t4 kit your turbo options are endless.
What do you do with your truck ? What's your HP goal ?
That will give us a idea of which direction to point you
Old May 22, 2015 | 10:00 PM
oldbird1965's Avatar
oldbird1965
I have the D66 on my old mule and I'm not impressed. Its not any better then stock really.
Old May 22, 2015 | 11:29 PM
Haywire-Powerstroke
My truck is my daily driver, use her all the time. Don't always tow with it but when I do want to be able to throw the skid steer behind her and take off. Not racing with it but I do like to make alittle noise sometimes and have alittle fun. I want to get it so that it's Fun truck to drive and give you that take you by the seat of your pants feeling haha. I was thinking somewhere around the 350-400hp range would be sweet?
Old May 23, 2015 | 12:25 AM
fordpride's Avatar
fordpride
6637 intake
3" dp 4" exhaust
Custom tuning
Stage1.5's
S366
T500 hpop
Intercooler
E fuel
Push rods
Head studs
Comp 910 valve springs
Built trans JW or BTS
That'll put you 390-425 hp reliable
Have 10k ready
