Oil & Lubrication
how tight to get filter?
Old Jul 28, 2003 | 06:34 PM
rebelbob's Avatar
rebelbob
i put a new oil filter on today.i was wondering how tight should i get it?i just snug it down.
Old Jul 28, 2003 | 06:44 PM
dtpatt2's Avatar
dtpatt2
Make sure you oiled the gasket and get it as hand tight as you can...
Old Jul 28, 2003 | 09:31 PM
Beast12's Avatar
Beast12
There are instructions on the oil filter itself. As dtpatt2 said make sure you oil the gasket. Goodluck!
-Matt
Old Jul 29, 2003 | 03:44 AM
BlueOvalFitter's Avatar
BlueOvalFitter
You need to ask around your neighborhood,who is a pipefitter(like me) and ask him for a 48" pipe wrench.... ....I always oil the gasket,spin it on till it touchs the base, then tighten up to (1) turn.
Old Jul 29, 2003 | 08:54 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Oil gasket, spin on until gasket contacts base, then another 3/4 turn. I place a piece of masking tape on the bottom of my filters, to be able to judge a 3/4 turn accurately.
Old Jul 29, 2003 | 10:01 AM
BlueOvalFitter
After it touches the base I just pick out a spot on the filter to determine the hand tightening up to (1) turn.
Old Jul 29, 2003 | 11:05 AM
jim henderson's Avatar
jim henderson
I haven't seen them all, but the filters I have seen all have the instructions printed right on the can or at least the box. If at first you don't succeed, read the freaking directions.
In general, oil the gasket. Clean the threads and mounting plate on the engine. Then turn the filter to just where you feel the gasket contact it and then turn the amount as printed on the can, usually 1/2 to 1 full turn. Do not turn it as tight as you can. If you are King Kong, you may never get it back off. Just turn the amount printed on the can or box.
Wouldn't hurt to inspect the filter before using it. Make sure the gasket is not damaged, check for rusty threads. Look inside to make sure there is no junk. I used to inspect filters as a part time job when I was in high school, you would be surprised at the number of filters we would reject for rust or damage. Don't assume the filter is fine just becuase it is new. It takes just a few seconds to look it over.
Good Luck,
Jim Henderson
Old Jul 29, 2003 | 11:51 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
I oil the gasket then screw it on 'til it's snug without the kung fu grip. Then tighten it 1/4 turn.
Scott
Old Jul 29, 2003 | 03:28 PM
BlueOvalFitter
Jim,you are correct.But,I open the box right there in the store to inspect the filter.That way if there is a problem,put that one aside or give it to the clerk and get another one.
Old Jul 29, 2003 | 03:30 PM
mikemc's Avatar
mikemc
"Jim,you are correct.But,I open the box right there in the store to inspect the filter.That way if there is a problem,put that one aside or give it to the clerk and get another one." ..I'm glad to hear its not just me.
Old Jul 29, 2003 | 06:11 PM
rebelbob's Avatar
rebelbob
i think king kong put my last filter on.took me a week to get the thing off.
Old Jul 29, 2003 | 06:22 PM
johnsdiesel's Avatar
johnsdiesel
Directly off of my Ford service DVD for my truck:
"Install the oil filter until the seal contacts the filter flange and then tighten 1-1/4 to 2 additional turns."
Old Jul 29, 2003 | 06:54 PM
'92BigBronco's Avatar
'92BigBronco
Make it as tight as you can, then tighten it another 1/2 a turn.....
Old Jul 30, 2003 | 02:30 PM
carpe_diem's Avatar
carpe_diem
I didn't know about this extra 1 turn thing, but I get it tight - hand-tight. Do not use any tools while putting it on!! You should not have to use tools taking it off.
Old Jul 30, 2003 | 02:45 PM
johnsdiesel
That's the first I've ever heard of that and I think Ford would disagree. If you don't get it tight enough it will leak. That's why they make oil filter wrenches.
