95 PSD info needed
Old May 20, 2015 | 02:20 PM
madpogue's Avatar
madpogue
I guess where I'm going is - could you find a two-speed diff with a tone ring on the ring gear?
VSS is non-contact, so yeah, pretty sure it's magnetic / Hall effect.
Old May 20, 2015 | 02:25 PM
cowmilker08's Avatar
cowmilker08
I think he has his axle picked out already.
Yes, it is.
Old May 20, 2015 | 03:00 PM
Steve Noland's Avatar
Steve Noland
I'm not sure if I could or not, that would be great. It would have to go in place of the existing Eaton 17121 diff. I do not want to change the 23,000# GVWR.
Old May 20, 2015 | 03:09 PM
cowmilker08
When you finish this project, you'll have to bring it out to RRE!
Old May 20, 2015 | 03:22 PM
Steve Noland
What is RRE?
Old May 20, 2015 | 03:29 PM
Steve Noland
I just found some YT vids of RRE! Is that the biggest sled they use?
Old May 21, 2015 | 07:38 AM
Steve Noland
A wiring harness, computer, IDM, etc from any automatic 95-97 PSD will work.
Are the computers locked or coded to a certain VIN on these?
Old May 21, 2015 | 08:14 AM
madpogue's Avatar
madpogue
No; there's no VIN information that comes up when you connect the truck to AE.
Even if there were, what would it be "locked" to? Someone connecting and reading codes/data would see the VIN of the donor, and yes, it wouldn't match the VIN on the vehicle's dash, but that certainly wouldn't affect how it runs.
Old May 21, 2015 | 08:19 AM
Steve Noland
Okay, thanks. Looking for parts now. There is a harness on ebay but I dont know for sure if it is for an auto trans or not.
Old May 21, 2015 | 08:21 AM
madMatador78's Avatar
madMatador78
I think he was concerned about putting components together and making sure they would work. Alot of the new stuff is that way where everything has to match VIN wise.
Old May 21, 2015 | 08:35 AM
Steve Noland
Exactly! Converting to a computerized drive train goes against everything in me, but I want this truck to be reliable and parts available when it is done.
I don't want to get it put together and have the computer laugh at me when I turn the key.
Old May 21, 2015 | 08:44 AM
madpogue's Avatar
madpogue
But in our case, there's only one "component" - the PCM. What would have to "match"? That's the beauty of the OBS PSD; for a partly digitally-run powertrain, it's about as simple as they come.
Old May 21, 2015 | 08:56 AM
  #28
Steve Noland
That's what I wanted to hear.
Old May 21, 2015 | 11:55 AM
  #29
cowmilker08
You are right, but since the reading will be taken from the other side of the pinion, which does change, there would be a need for two tone rings.
You could have two tone rings and two VSS. Then switch between the two sensors electronically, tie into the switch for the axle and your good to go!
Old May 21, 2015 | 12:08 PM
  #30
madMatador78
Very true. And thats what I like about these trucks!!!
