Sponsored by: Real Truck
Big Rig wheel upgrade
Old May 20, 2015 | 05:25 PM
waynenichols's Avatar
waynenichols
I looked into getting custom made 22.5" rims by Alcoa that way its an easy swap they are a little more but the adapters are not there I am thinking it will have the swap done next month when I get back from work. thanks for all yals help and advice
Old May 20, 2015 | 07:32 PM
scotttahoe's Avatar
scotttahoe
Pleas show some pics when you do!
Old May 21, 2015 | 01:20 PM
waynenichols
I will post many pics when it is done
Old May 21, 2015 | 01:36 PM
WickdL's Avatar
WickdL
Alcoa doesn't drill their 22.5 wheels to the f450 bolt pattern. You will need an adapter to run them. Unless you know someone?
AmericanForce however does but they are pricey. Set of 6 wheels around $5500.00
Old May 22, 2015 | 08:50 AM
05F250DSL's Avatar
05F250DSL
I just spoke with my neighbor he has 285/75 22.5 lo profile. He said he would has been thinking about going to the taller tires but doesn't think he has the clearance.
Old May 22, 2015 | 09:36 AM
lee00's Avatar
lee00
Originally Posted by fordman19762003
have you priced the larger tires? You're probably looking at $3k for six tires plus around another $1500 or so for rims.
The downside is the initial cost...upside is longjevity of tread wear....other down side is stickiness of the tread...more likely to slide on wet and snowy ground...
Old May 22, 2015 | 02:09 PM
scotttahoe's Avatar
scotttahoe
Sorry, I'm not buying that. With the correct tread the semi tires have great traction. With larger fat tires they float on snow which is bad traction and semi tires being like pizza cutters they cut through the snow in which gives you traction. On ice your screwed either way.
Old May 22, 2015 | 02:22 PM
lee00's Avatar
lee00
With a 20,000 lbs rig on them and/or 40,000 lbs load yes....with a 6,000 lbs truck not so much....the friction generates heat which softens the rubber... think motorcycle tires...the hotter the more grip....
This is also why I am against nitrogen inflation.... keeps the tire cooler aka harder and improves fuel mileage... but increases stopping distance...
Old May 22, 2015 | 08:00 PM
waynenichols
I am in the south and not much snow down here but the wheel upgrade will give me a lot more mile pulling my camper, that is the main reason for the upgrade. I have put as much as 1100 miles in a month pulling it and the Continental tires are good but they dont last long.
Old Jan 31, 2018 | 03:05 PM
Daniel Riemer's Avatar
Daniel Riemer
2008 f 450 to big rig adaptors
008 f 450
guys I want to go from standard F450 2008 bolt pattern with an adapter to the 10 by 285.75 Big Rig bolt pattern so I can get 22.5 inch wheels and put big rig tires on my F450 that has an 8 inch lift kit. Where can I get these adapters?
Old Feb 5, 2018 | 07:59 AM
WickdL's Avatar
WickdL
Originally Posted by Daniel Riemer
008 f 450
https://ktperformance.net
http://www.tnwheelandtire.com
Old Feb 5, 2018 | 05:55 PM
4Wheelgreg's Avatar
4Wheelgreg
I'm a new guy here but have had 22.5 on SRW and DRW trucks on F350's , Dodge 3500's and GMC 3500 trucks . Ford Straight axle trucks always seemed to handle the bigger wheels better . Brake and fuel milage have a huge relation to your driving , if your not stopping and go driver I have seen less than 5% fuel loss difference .
On the other hand have seen guys eat up brakes and 15% or more fuel milage loose .
Don't forget 1300 for the wheel adapters .
I just picked up a low milage 2016 F-450 and for me 245/70R19.5 TOYO is a great combination , I'm only towing big boats and do as I say and not as I do .
Another factor is where you live as far as tires , if its dry and flat your golden and can run just about any tire , get into the cold and snowy and wet Northeast you have to choose wisely .
Most guys that do 22.5 pic the wrong tire and get stuck on wet grass with there hard compound tires .
You can mount 285's on 6" have done it for guys that don't tow any heavy loads with show and not go trucks . The manufactures require 6.50 or wider and I would say the same with a truck thats working .
I have built a lot of custom trucks over the years and if your just out for looks or towing the boat 22.5s look cool but real world used 2015 /2016 F-450 with the big dana s130 is the only set up 22.5 with the right gear I would use 22.5 on .
Thats just my 2$
burkeiceking
49
May 10, 2018 06:14 AM
Ak Ford Man
20
Feb 4, 2011 12:42 PM
bmarkline
19
Jun 27, 2009 07:55 PM
bio-d
May 12, 2007 12:40 PM
duke_snyder
41
Mar 26, 2007 10:50 AM
