Where do I jack the engine?
Old May 18, 2015 | 05:48 PM
MinesRugger's Avatar
MinesRugger
1978 F250 400 4x4
Alright, so I've been reading around for the past two hours, trying to find the right answer for my issue.
I don't have access to an engine puller until the weekend, and I have a very rare three hours free tonight, so I'd like to get my oil pan pulled out this evening.
I read a few posts that say to jack the engine up from the floor via the oil pan and a board. I also read a few posts that say NEVER EVER jack the engine from the bottom because its too heavy and to just pull the engine out all the way. I also read some posts that said to jack it from the harmonic balancer. I also read some posts that say to just jack up the driver side from the cross member...
So.... what is the best plan of attack? Where am I supposed to put the floor jacks? I've already pulled the radiator so I have some extra clearance there. Going to pull the starter tonight too. According to the Chiltons, that should be it!
Thanks in advance for your ideas.
Old May 18, 2015 | 07:47 PM
Jdeshler's Avatar
Jdeshler
Take the motor mount bolts off and loosen the transmission mount bolts.. Use a jack under the harmonic balance to lift it until it touches the firewall and have at it..
Make sure you support the engine so it does not FALL ON YOU!
Old May 18, 2015 | 08:11 PM
HIO Silver's Avatar
HIO Silver
I use the pan rail method using a piece of redwood lumber because it is soft and less likely to deform the pan rail. Block rails are cast thick and solid.
I avoid jacking using the balancer because it rides on an engine bearing.... and bent/deformed crank snouts (however slight) is never a good thing IMO.
Old May 18, 2015 | 09:53 PM
Jeremy Kamutzki's Avatar
Jeremy Kamutzki
I successfully used the bottom of the oil pan method on my 300. 10" long piece of 1x6 and it went up no problem. Pan wasn't distorted or anything, no leaks after reinstalling gasket.
Old May 18, 2015 | 10:34 PM
MinesRugger
Thanks guys! I really appreciate it. I'll post some pics sometime this week, as my free time tonight got snatched up with some QT with my daughters!
Old May 18, 2015 | 11:12 PM
jconis's Avatar
jconis
I was able to get my pan off my 77 f250 with a 400 and c6, just by jacking the truck and relaxing the front axle, removing the exhaust and the pan slid right out. Done it twice in the last 3 weeks. Just another way to skin a cat.
Jeff
Roguespirit
1983 - 2012 Ranger & B-Series
Nov 20, 2006 03:50 PM
poffutt
1978 - 1996 Big Bronco
Mar 31, 2006 11:44 AM
caesarnapolitano
Dec 29, 2005 07:18 AM
sharkdance
Mar 25, 2005 08:34 AM
77fordguy
Garage & Workshop
15
Oct 22, 2004 08:04 AM
