B1484 Code Fix!
Old May 18, 2015 | 02:22 PM
FordGuy85's Avatar
FordGuy85
B1484 Code Fix!
Check engine light came on this week. Said B1484 code Brake pedal open circuit.
Anyone ever had this code pop up?
I tried disconnecting the battery for a few minutes to reset but light came right back.
Old May 18, 2015 | 03:29 PM
projectSHO89's Avatar
projectSHO89
Let me google that for you
Old May 18, 2015 | 06:25 PM
FordGuy85's Avatar
FordGuy85
I already googled it.
Old May 19, 2015 | 06:42 PM
FordGuy85's Avatar
FordGuy85
Could not find much usefull info.
Old May 20, 2015 | 10:24 AM
F150Torqued's Avatar
F150Torqued
Post '05 Diagrams may be helpful
@FordGuy85
My factory service manual (for an '05 F150) doesn't show code B1484 among the "B" codes, but I notice a couple of 'fuses' associated with the brake pedal circuits, two of which wire to the PCM (see diagram SW-1).
Seems one of those would have to be responsible for the code if it can detect an "OPEN" circuit . Certainly, the PCM can't tell the difference between a blown fuse and a broken wire, so I copied the Fuse Location diagram too.
I Can't imagine there being a big difference between the '04 and any of the 04 to 08 models. I've generally found it to be very applicable on everything for my '04. You should be able to download and print / save the diagrams from here:
www.devoll.com/Public/f150-wiring-Brake-Pedal-SW-1.pdf
www.devoll.com/Public/f150-wiring-Brake-Pedal-SW-2.pdf
www.devoll.com/Public/f150-wiring-Brake-Pedal-SW-3.pdf
www.devoll.com/Public/ELECTRICAL-COMPONENT-LOCATOR~CJB.pdf
Hope this helps
jwsrules
6.7L Power Stroke Diesel
Aug 7, 2024 08:09 AM
bvbunky195
Escape & Escape Hybrid
Apr 30, 2010 07:32 PM
55F250
General Automotive Discussion
Sep 5, 2009 02:14 AM
airman90
Modular V8 (4.6L, 5.4L)
Sep 15, 2007 05:39 AM
fastf150
Sep 26, 2003 07:21 AM
