Fuel pressure?
Old May 18, 2015 | 11:55 AM
Tom14032's Avatar
Tom14032
Fuel pressure?
Hey, I just installed a gauge from Glow shift and my fuel pressure is 55 idling. between 52 and 54 just normal driving and 49 WOT. I did the blue spring a couple weeks ago and new motor craft filters at the same time. Are these normal pressures or is something wrong?
Old May 18, 2015 | 12:25 PM
Money-Pit's Avatar
Money-Pit
With a new blue spring you should see 60-65 psi normally. Then again, I don't know how accurate glow shift gauges are.
Old May 18, 2015 | 12:41 PM
Texas Bob's Avatar
Texas Bob
I have done the blue spring upgrade and I see a consistent 60+ PSI on my Glow Shift Fuel Pressure Gauge.
Old May 18, 2015 | 12:54 PM
Tom14032's Avatar
Tom14032
Hmmmm ..... Could my HFCM be going then?
Old May 18, 2015 | 01:04 PM
TooManyToys.'s Avatar
TooManyToys.
Did you get the blue spring in a Motorcraft or international package or as an aftermarket product?
Old May 18, 2015 | 01:11 PM
Tom14032's Avatar
Tom14032
I bought it off amazon from a ford dealer...
Fuel Pressure Regulator Kit Ford F-Super Duty 6.0 ALL 3C3Z-9T517-AG 3C3Z9T517AG
by Ford
Old May 18, 2015 | 03:41 PM
dannyboy950's Avatar
dannyboy950
Personally I have never known of a Ford dealer selling anything on amazon or ebay.
Old May 18, 2015 | 05:00 PM
TooManyToys.
Marketeers are selling Motorcraft products through Amazon, but your right I'm not noticed any Ford dealers selling, but haven't looked much. That being said, the question of was it in a Motorcraft or International package was not answered. More likely if shipped by Amazon it was, but still an open question.
Old May 18, 2015 | 05:16 PM
jsm180's Avatar
jsm180
Old May 18, 2015 | 06:46 PM
Tom14032's Avatar
Tom14032
Originally Posted by jsm180
Yes, that's the packaging and kit I bought. I will say it also came with a new cover and while the spring was blue, it was a little longer as well.
Old May 18, 2015 | 07:15 PM
TooManyToys.
Sorry about being a PITA to make sure it was Motorcraft.
Old May 18, 2015 | 07:43 PM
Tom14032's Avatar
Tom14032
No problem I understand your just making sure. On my way home today I did see a 48 psi flash when going wot. I suppose I could put the stock spring back in and see if there is a change. Would an hfcm cause the lower pressure?
Old May 18, 2015 | 08:57 PM
TooManyToys.
The very first thing we would do in any test was to check gauge or transducer calibration. It's a pita like me, but I think that is where you have to start. Even if that means installing a mechanical gauge with hose or tubing to recheck the motor, or setting up a collection of fittings so you can put a guage along with this sensor onto an air line and check the two.
The alternative is flipping springs, again without knowing the gauge calibration what does that get you, or flipping HFCM. Both take time and expense and you only be checking against your unknown gauge. What if they all show the same reading ..... Damn guage comment will be coming.
Some smarta** will probably post well how do you know the second gauge is right? It's a slippery slope.
Old May 18, 2015 | 09:18 PM
mustang_309's Avatar
mustang_309
Yes a failing pump in the HFCM can cause low system pressure. Are you running tuned? That also puts extra demand on the pump. When you did your blue spring did you require the black bushing that comes in the kit? And if so did you make sure to install the oring that goes between the black bushing and the fuel filter housing?
Old May 18, 2015 | 09:38 PM
junior125's Avatar
junior125
not every regulator requires that black bushing, I know my 05 doesn't, but for sure sounds like a pump that is on it's way out
