96 Explorer 4wd Problems
Old Jul 28, 2003 | 01:54 PM
markmustangs's Avatar
markmustangs
I am still having problems with the 4wd system on my 96 explorer. I have replaced the transfer case twice and have also replaced to transfer case computer (GEM Module). It still has the same problem. Whenever the car is started, or when the ignition is turned to on, the transfer case actuator will switch to 4wd low and then back to 2wd. This causes the car to roll back for a second as the transfer case is between gears. If i try to engage it in drive or reverse at the same time the transfer case is doing this, It will make a horrible metal grinding sound. I have to wait about 15 seconds after starting it to avoid this. The 4wd Auto still works( it just actuates the electronic clutch), but If I turn the switch to 4wd low, it will do nothing, and the 4wd lights will start to flash. Has anyone had any problems like this before? Also does anyone have a wiring diagram for the 4wd system on this car?? Any info would be greatly appreciated.
underdogl3
Feb 18, 2016 07:00 PM
myf16
Jul 29, 2012 07:43 PM
fpratt
Oct 21, 2010 02:43 PM
markmustangs
Jul 23, 2003 09:45 AM
rberghef
Feb 21, 2003 09:37 AM
