Icp low and code p1661
Old May 16, 2015 | 05:00 PM
1973dieselhighboy's Avatar
1973dieselhighboy
Ok so I have been battling icp issues for a couple years or so new t500 from Joey less then a thousand miles injectors just got fixed last year around 500 miles on them and my icp drops to 2k under light to heavy load and and eventually throws a code and defaults. I am getting code p1661 when I pull codes along with icp low.
What the hell is this code.
Please don't tell me I have a bad pump I had a modded 17 before and it acted the same and I have talked to Joey and he said he will test it, I am trying to get all electrical issues figured out first. My truck has had 2 ipr, icp, tps, map, and been threw my wiring with a fine tooth comb, and everything checks out no chafs shorts or opens. Want to figure this icp issue out before next year when it's time to buy a different truck.
Old May 16, 2015 | 05:12 PM
fordpride's Avatar
fordpride
AS1 DIAGNOSTIC TROUBLE CODE (DTC) 1661 DTC 1661 indicates that the output circuit check is low. Possible causes: -- Low battery voltage -- Circuit failure -- Faulty powertrain control module (PCM) Perform charging system and battery tests. Is charging system OK? Yes: GO to «AS2». No: REPAIR charging system as required.
AS2 VREF CIRCUIT CHECK Disconnect PCM. Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary. Install breakout box, leave PCM disconnected. Disconnect manifold absolute pressure (MAP) sensor connector. Measure resistance from Pin 90 to VREF Circuit 351 (BR/W) at the MAP sensor connector. Is resistance less than 5 ohms? Yes: GO to «AS3». No: IDENTIFY VREF circuit fault. GO to Pinpoint Test «B1».
AS3 VPWR CIRCUIT CHECK PCM disconnected. Key on. Measure resistance from Pins 71 and 97 to the positive battery post. Is resistance less than 5 ohms? Yes: GO to «AS4». No: IDENTIFY VPWR circuit failure. GO to Pinpoint Test «A1».
AS4 PCM GROUND CIRCUIT CHECK PCM disconnected. Key off. Measure resistance from Pins 25, 51, 76, 77 and 103 to the negative battery post. Is resistance less than 5 ohms? Yes: REPLACE PCM. RETEST system. No: REPAIR ground circuit fault. GO to Pinpoint Test «A10».
A1 DIAGNOSTIC TROUBLE CODES (DTCs) 0563/0562/0560: CHECK BATTERY VOLTAGE Key on, engine off. Measure voltage across battery terminals. Is voltage greater than 9.5 volts? NOTE: DTC 0563 may be a temporary condition with a 24 volt jump start. DTC 0562 may be a temporary condition at crank only. 0563 -- System voltage high 0562 -- System voltage low 0560 -- System voltage malfunction Yes: F-Series, GO to «A2». No: SERVICE discharged battery. REFER to Section 14-00 in Body, Chassis Service Manual.
A2 CHECK VOLTAGE AT MAXI FUSE 9 Measure voltage between maxi fuse 9 at power distribution box to battery negative post. Is battery voltage present? Yes: GO to «A3». No: REPAIR open in Circuit 37 (Y) between the power distribution box and the starter relay.
A3 CHECK MAXI FUSE 9 Check maxi fuse 9 power distribution box. Is fuse blown? Yes: REPAIR short to ground and REPLACE maxi fuse 9. No: GO to «A4».
A4 CHECK CIRCUIT 37 (Y) TO RELAY Key off. Remove PCM relay. Remove maxi fuse 9. Measure resistance between the nonpower side of the maxi fuse 9 to Circuit 37 (Y) of the PCM relay connector. Is resistance less than 5 ohms? Yes: GO to «A5». No: REPAIR open in Circuit 37 (Y) between fuse and relay connector.
A5 CHECK IGNITION FEED TO DIODE Remove diode from power distribution box. Key on. Measure voltage from battery ground to ignition feed side of diode connector. Is battery voltage present? Yes: GO to «A6». No: REPAIR open in ignition feed Circuit 16 (R/LG) or ignition switch.
A6 CHECK DIODE Key off. Disconnect diode. Does diode check OK? Yes: F-Series, GO to «A7». No: REPLACE diode.
A7 CHECK CIRCUIT 175 (BK/Y) Measure resistance between nonpower side of diode connector Circuit 175 (BK/Y) to PCM relay connector. Is resistance less than 5 ohms? Yes: GO to «A8». No: REPAIR open in Circuit 175.
A8 CHECK GROUND CIRCUIT 57 (BK) AT RELAY Key off. Measure resistance between battery negative to Circuit 57 (BK) at PCM relay connector. Is resistance less than 5 ohms? Yes: GO to «A9». No: REPAIR open in Circuit 57 (BK).
A9 CHECK CIRCUIT 361 (R) FROM RELAY TO PCM Disconnect PCM and inspect for damaged or pushed-out pins, corrosion, loose wires, etc. Service as necessary. Measure resistance between Circuit 361 (R) at PCM relay connector to Test Pins 71 and 97. Is resistance less than 5 ohms? Yes: GO to «A10». No: REPAIR open in Circuit 361 (R) between relay and PCM.
A10 CHECK PWR GND CIRCUIT CONTINUITY Key off. Install breakout box. Leave PCM disconnected. Inspect for damaged or pushed-out pins. Measure resistance between battery negative post and Test Pins 25, 51, 76, 77 and 103 at the breakout box. Is each resistance less than 5.0 ohms? Yes: F-Series, GO to «A11». Econoline, GO to «A14». No: SERVICE open in PWR GND circuit. REMOVE breakout box. RECONNECT PCM. RERUN Scan Tool Diagnostic Test.
A11 CHECK PCM RELAY Key off. Disconnect maxi fuse 9. Install PCM relay. Breakout box install, PCM disconnected. Key on, engine off. Measure resistance between nonpower side of maxi fuse 9 to Test Pins 71 and 97. Is resistance less than 5 ohms? Yes: If fault is still present, REPLACE PCM. No: REPLACE PCM relay.
B1 CHECK VEHICLE BATTERY POWER CIRCUIT Key off. Disconnect PCM. Inspect for damaged or pushed-out pins, corrosion, loose wires, etc. Service as necessary. Install breakout box and connect PCM to breakout box. Key on, engine off. Measure voltage between Test Pins 55, 71 and 97 to Test Pins 25, 51, 76, 77 and 103 at the breakout box. Note voltage. Measure voltage across battery terminals. Note voltage. Are both voltages greater than 10.5 volts, and are both voltages within 1.0 volt of each other? Yes: GO to «B2». No: Key off, RECONNECT sensor (if applicable). GO to «A1».
B2 CHECK VREF VOLTAGE Key on, engine off. Breakout box installed, PCM connected. Measure voltage between Test Pin 90 and Test Pin 91 at the breakout box. Is voltage between 4 volts and 6 volts? Yes: GO to «B3». No: Less than 4 volts, GO to «B5». Greater than 6 volts, GO to «B4».
B3 CHECK VREF AND SIG RTN CIRCUITS FOR CONTINUITY Key off. Sensor that sent you here disconnected. Breakout box installed. Disconnect PCM. Measure resistance between Test Pin 90 at breakout box and VREF circuit at vehicle harness connector of the sensor that sent you here. Measure resistance between Test Pin 91 at breakout box and SIG RTN circuit at vehicle harness connector of the sensor that sent you here. Is each resistance less than 5.0 ohms? Yes: Reference voltage OK. REMOVE breakout box. RECONNECT all components. RERUN Scan Tool Diagnostic Test. No: SERVICE open in VREF or SIG RTN circuits. REMOVE breakout box. RECONNECT all components. RERUN Scan Tool Diagnostic Test.
B4 CHECK FOR EXCESS VOLTAGE ON VREF CIRCUIT Key off. Breakout box installed. Disconnect PCM. Disconnect NGS Tester. Key on, engine off. Measure voltage between Test Pin 90 at the breakout box and battery ground. Is voltage less than 0.5 volts? Yes: REPLACE PCM. REMOVE breakout box. RECONNECT all components. RERUN Scan Tool Diagnostic Test. No: SERVICE short to power in vehicle harness. REMOVE breakout box. RECONNECT PCM and sensor. RERUN Scan Tool Diagnostic Test.
B5 SIG RTN CIRCUIT CHECK Key off. Breakout box installed. PCM connected. Measure resistance between Test Pin 91 and Test Pins 25, 51, 76, 77 and 103 at the breakout box. Is each resistance less than 5 ohms? Yes: GO to «B6». No: REPLACE PCM.
B6 CHECK FOR SHORTED ACCELERATOR PEDAL (AP) SENSOR Key off. Breakout box installed, PCM connected. Disconnect AP sensor from vehicle harness. Inspect for damaged or pushed-out pins. Key on, engine off. Measure voltage between Test Pin 90 and Test Pin 91 at the breakout box. Is voltage less than 4.0 volts? Yes: Leave AP sensor disconnected. GO to «B7». No: REPLACE AP sensor. REMOVE breakout box. RECONNECT all components. RERUN Scan Tool Diagnostic Test.
B7 CHECK FOR SHORTED CAMSHAFT POSITION (CMP) SENSOR Key off. Breakout box installed, PCM connected. Disconnect CMP sensor. Inspect for damaged or pushed-out pins. Key on, engine off. Measure voltage between Test Pin 90 and Test Pin 91 at the breakout box. Is voltage less than 4.0 volts? Yes: Leave CMP sensor disconnected. GO to «B8». No: REPLACE CMP sensor. REMOVE breakout box. RECONNECT PCM and sensors. RERUN Scan Tool Diagnostic Test.
B8 CHECK FOR SHORTED INJECTION CONTROL PRESSURE (ICP) SENSOR Key off. Breakout box installed, PCM connected. Disconnect ICP sensor. Inspect for damaged or pushed-out pins. Key on, engine off. Measure voltage between Test Pin 90 and Test Pin 91 at the breakout box. Is voltage less than 4.0 volts? Yes: Leave ICP sensor disconnected. GO to «B9». No: REPLACE ICP sensor. REMOVE breakout box. RECONNECT PCM and sensor(s). RERUN Scan Tool Diagnostic Test.
B9 CHECK FOR SHORTED EXHAUST BACK PRESSURE (EBP) SENSOR Key off. Breakout box installed, PCM connected. Disconnect EBP sensor. Inspect for damaged or pushed-out pins. Key on, engine off. Measure voltage between Test Pin 90 and Test Pin 91 at the breakout box. Is voltage less than 4.0 volts? Yes: Leave EBP sensor disconnected. GO to «B10». No: REPLACE EBP sensor. REMOVE breakout box. RECONNECT PCM and sensor(s). RERUN Scan Tool Diagnostic Test.
B10 CHECK FOR SHORTED MANIFOLD ABSOLUTE PRESSURE MAP SENSOR Key off. Breakout box installed, PCM connected. Disconnect MAP sensor. Inspect for damaged or pushed-out pins. Key on, engine off. Measure voltage between Test Pin 90 and Test Pin 91 at the breakout box. Is voltage less than 4.0 volts? Yes: Leave MAP sensor disconnected. GO to «B11». No: REPLACE MAP sensor. REMOVE breakout box. RECONNECT PCM and sensor(s). RERUN Scan Tool Diagnostic Test.
B11 CHECK FOR SHORTED BAROMETRIC PRESSURE (BARO) SENSOR Key off. Breakout box installed, PCM connected. Disconnect BARO sensor. Inspect for damaged or pushed-out pins. Key on, engine off. Measure voltage between Test Pin 90 and Test Pin 91 at the breakout box. Is voltage less than 4.0 volts? Yes: Leave BARO sensor disconnected. GO to «B12». No: REPLACE BARO sensor. REMOVE breakout box. RECONNECT PCM and sensor(s). RERUN Scan Tool Diagnostic Test.
B12 CHECK VREF CIRCUIT FOR SHORT TO GROUND Key off. Breakout box installed. Disconnect PCM. With all six of the three-wire sensors (AP, CMP, ICP, EBP, MAP and BARO) disconnected, measure resistance between Test Pin 90 and Test Pins 25, 51, 76, 77, 91 and 103 at the breakout box. Are all resistances greater than 10,000 ohms? Yes: REPLACE PCM. REMOVE breakout box. RECONNECT all components. RERUN Scan Tool Diagnostic Test. No: SERVICE short to ground. REMOVE breakout box. RECONNECT all components. RERUN Scan Tool Diagnostic Test.
Old May 16, 2015 | 05:13 PM
fordpride's Avatar
fordpride
What does the icp do with the chip removed
Old May 16, 2015 | 06:11 PM
1973dieselhighboy
With the chip out it calls for 2500 icp stays steady and at 35-40% ipr and have never checked codes to see but same issue with 2 chips, have tried that cause I thought that might be the issue.
Old May 16, 2015 | 06:14 PM
fordpride's Avatar
fordpride
Is both chips done by the same tuner ?
Old May 16, 2015 | 08:23 PM
1973dieselhighboy
Yes but multiple tunes I have gone threw probably 10 different tunes with same issue and his truck runes great with the same tunes
Old Oct 24, 2022 | 02:35 PM
ScottS96F350D's Avatar
ScottS96F350D
4th Gear
Does this apply to 1996 7.3?
Does this apply to a 1996 F350 7.3? Engine is a 97.
Old Oct 24, 2022 | 03:10 PM
knottyrope's Avatar
knottyrope
yes it does
Old Oct 24, 2022 | 03:17 PM
ScottS96F350D
4th Gear
Stupid question: What is a brakeout box?
Old Oct 24, 2022 | 03:28 PM
knottyrope's Avatar
knottyrope
ford tool for testing
Old Oct 24, 2022 | 03:34 PM
ScottS96F350D
4th Gear
Can I get one? Ford tech only?
Old Oct 24, 2022 | 03:58 PM
knottyrope's Avatar
knottyrope
Amazon Amazon
I see they have some on amazon
Old Oct 24, 2022 | 07:43 PM
ScottS96F350D
4th Gear
They proud of that tool. I might use that one time. $$$
Old Oct 24, 2022 | 08:08 PM
Action4478's Avatar
Action4478
Try a used PCM . Mine was 50 dollars . TDE 1
Old Oct 25, 2022 | 11:00 AM
knottyrope's Avatar
knottyrope
you can use a meter with out the breakout box but the pins can be fun to get to
bobber1
1983 - 2012 Ranger & B-Series
32
Aug 26, 2025 11:54 AM
scottddove
Jul 31, 2015 02:02 PM
Daveoh
May 20, 2012 01:44 PM
gramicko
Apr 24, 2010 12:27 PM
wildspirit78
Dec 26, 2007 02:52 PM
