1978 - 1996 Big Bronco
door locks don't work
Old Jul 28, 2003 | 10:12 AM
borinut's Avatar
borinut
Red face door locks don't work
hi guys, I'm new here and I have a problem with my bronco 1994 engine 5.0 :
1. a power lock buttons don't work
2. inflatable device inside seats stopped work also
I found and checked a fuse in power box which located on left under dash, it
looks like there no prob. (fuse #12 in a box) actually I checked all fuses there and all of them are working just fine.
I think here suppose to be a second fuse or something which makes double this circuit.... yes? no?
if somebody can understand me and have any ideas please help , thank you very much!!!!!
Old Jul 28, 2003 | 11:02 PM
greystreak92's Avatar
greystreak92
Actually, its a circuit breaker rather than a fuse in the #12 position of the fuse block. There is no other current interrupting device (fuse or C.B.) in the line. It feeds the door locks, lumbar motors, shift control module, and rear window keyswitch in the tailgate. There are two splice points beyond the C.B. that I would try to track down. The first splits the wiring out to the T-gate keyswitch, shift module, and the door locks/lumbar motors. The second splice splits out the door locks and each lumbar motor individually. If the T-gate keyswitch still works and you aren't experiencing shift problems, I would suggest hunting down that first splice point and checking it with a test light or multimeter.
Old Aug 11, 2003 | 02:25 AM
Bronco555's Avatar
Bronco555
i have problems with my door locks. i need new cylindars i think. they grind when i lock the doors. anyone know how to change them????
