Sponsored by: Kumho
Rear End Confusion????
Old Jul 28, 2003 | 09:53 AM
Redthunder's Avatar
Redthunder
The code on the door sticker is H9, which according the tech article, I should have a 3.55 Limited Slip. However, the tag on the rear axle reads:
S837J
3L55 88 4L05
I was at the local ford dealer and they said I had a 4.05 Locker.
I am not convinced of either. Both wheels spin in mud and snow or any thing loose, (will not spin on pavement) and performance dropped some when I went to the bigger tires.
Also, am I to assume that whatever is in the rear will be in the front axle too?
Old Jul 28, 2003 | 11:50 AM
StrangeRanger's Avatar
StrangeRanger
3L55 is a 3.55 LS.
Find another dealer, that one is an idiot. There were no 4.05:1 ratios in a Ford within living memory and there were no lockers offered in 1995 F150s.
Old Jul 28, 2003 | 01:17 PM
Big Orn's Avatar
Big Orn
I second Strangeranger. 3.55 limited Slip made in 1994 maybe November the 5th? But definitely not a 4.05 LS. The guy was drunk or on drugs.
Old Jul 28, 2003 | 02:43 PM
RRMike's Avatar
RRMike
The guy could well have been drunk or on drugs like Orn says. If you only read him the "4L05" part then I could at least think maybe he was a new guy that was told how to decode those numbers. If you gave him the whole thing then he's an idiot. The first 3 numbers in the row are the ratio and if there's an L in between the first two then it has a Limited Slip.
thelonerangerxlt's Avatar
thelonerangerxlt
Redthunder, you'll also have a 3.55 in the front, but it'll be an open diff, not a limited slip.
Old Jul 28, 2003 | 02:46 PM
RRMike's Avatar
RRMike
Oh also yes the front will have the same ratio or 3.54 which is close enough. Sometimes the ratio will be 1 or 2 points off. It doesn't hurt anything since we all know better than to drive on high traction surfaces in 4x4.
Did f150's have 8.8 rear ends in 95? That's what it looks like. Did they go to the 9.75 visteon's in 97 or 98 with the new body style?
is300wrx
2004 - 2008 F150
21
Nov 13, 2014 10:33 PM
bigdaddyII
2004 - 2008 F150
Jan 23, 2012 05:47 PM
1 Ton Tommy
Sep 5, 2010 06:04 PM
dmontser
All Things Towing
15
Oct 31, 2004 11:55 AM
