spark knock
Old May 12, 2015 | 10:09 PM
1990-f250's Avatar
1990-f250
spark knock
I have a 89 f150. When warm I believe it has some spark knock. I have tried seafoam and It didnt really help. 91 octane helped slightly. I have not checked the timing yet, but it doesn't idle high or anything like the timing is to high. Also it kind of surges at idle sometimes, and it used to die when first started until I switches to 91 octane. Any suggestions?
Old May 12, 2015 | 11:00 PM
Toplait's Avatar
Toplait
I would check for codes.....Kind of sounds like a sensor
Old May 13, 2015 | 07:57 AM
BLK79's Avatar
BLK79
I would verify base timing is correct (with SPOUT removed). That may be your issue.
Old May 13, 2015 | 08:09 AM
rla2005's Avatar
rla2005
Code check and base timing are the way to go before spending money on parts or that expensive 91 octane fuel.
Old May 13, 2015 | 09:08 AM
1990-f250's Avatar
1990-f250
Yeah I better check the timing, what else could cause spark knock besides carbon deposit or advanced timing?
Old May 13, 2015 | 10:42 AM
rla2005's Avatar
rla2005
Wrong heat range spark plugs. Faulty sensor feedback signal triggering the PCM to add more timing/pull out enough.
FYI..on a modern EFI engine too much initial timing will not affect idle RPM, the computer adjusts for that..
Old May 13, 2015 | 11:58 AM
1990-f250's Avatar
1990-f250
But on our trucks it does right? When I did the timing on my 90 f250 the idle went up and down with the timing
Old May 13, 2015 | 12:36 PM
BLK79's Avatar
BLK79
Incorrect base timing on EFI 460's doesn't seem to affect idle RPM, although it seems to affect idle quality a little.
Old May 13, 2015 | 02:16 PM
1990-f250's Avatar
1990-f250
Ok maybe thats what i was hearing. Your probably right
72Highboy4x4
Jun 11, 2012 08:56 AM
turboguy
Nov 9, 2005 12:21 PM
cantrma
1997 - 2003 F150
Jan 25, 2005 12:10 AM
phoneman71
Nov 8, 2004 06:07 AM
PAUL_2
Nov 19, 2000 12:50 PM
