Okay - my trailer has a really nice Generator and Inverter / Battery charger but has nothing for Transfer Switch other than manually moving my shore power plug from the Generator plug to the pole..
I bought a nice Surge under/over voltage Protector, but now need to get my act together and find an Automatic Transfer switch that will work with everything else I have.
I have 50amp service in the trailer and was looking at the following unit, but am also looking for other options.. I won't say that money is no object but I don't want a cheap piece o-crap that will nuke itself the third time it's used...
Nothing the matter with this one. Darn little difference between them in my experience. I see no benefit in double surge protection, but also no harm. Of course for the absolute best in reliability, it is hard to beat taking the plug out of one receptacle in into the other.
Steve
I liked the idea of the plug also, but the instructions for my Surge Prtector said in BOLD CAPS to not wire it or plug it into an Inverter... Well, that kinda screws me up. So the surge protector will be wired into the shore line (plug) and the output of the surge protector will go to one side of the transfer switch, the Gennie and Inverter will go to the other side of the transfer switch.
Confused yet???
I think you are making a mistake in interpretation. I believe what the instructions say is not to plug it into or wire it into the output side of an inverter as the inverter bonds the neutral/ground when there is not shore power and a surge guard would interpret that as a fault. There is a bond that opens and closes when shore power is disconnected.
I would call them directly and ask them as I have done exactly what you are saying shouldn't be done without a problem. I am not saying to do anything until you get this clarified, but people with portable surge guards and power management systems do this every time they plug in the shoreline don't they (if I am following your concern).
