Part number HELP !
Old May 11, 2015 | 08:17 AM
candoo's Avatar
candoo
Part number HELP !
I have a 1966 F350/352/NP435/2wd. Looking for motor mounts.
It has one front mount TFAA-6039-1 UPPER
CITT-6038-B LOWER piece. The two bell housing mounts have two numbers on them C5TA-6068-L-green AND C4TA-6068-A-YELLOW.
Looking at NPD shows a confusing array of choices with basic part numbers, mostly for the back mounts.Looks like the front is straight forward using the part numbers F-6038-14 AND T-6039-1. The rear does not show my truck and many choices with part numbers F-6068-1/2/3/4. Closest seems to be a F100-250 4by2 65 to 67 F-6068-2. Need to order these ASAP as my new motor comes in two weeks.
Old May 11, 2015 | 08:42 AM
candoo's Avatar
candoo
Old May 11, 2015 | 08:45 AM
candoo's Avatar
candoo
Old May 11, 2015 | 03:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You are unaware of the quantity of the mounts. There is 1 upper and 1 lower front. 2 upper and 2 lower rear (see pics).
352: These parts are the same: 1965 F100/250 4WD - 1965/66 F350 - 1966 F250 4WD
The numbers marked on your mounts are ID numbers, not part numbers.
From the 1964/72 Ford Truck Parts Catalog - Text section 60.7:
TFAA-6038-A .. Upper Front Insulator-Rectangular / Obsolete
MILLER OBSOLETE PARTS in Binghamton NY has 6 = 607-722-5371.
GREEN SALES CO. in Cincinnati OH has 23 = 800-543-4959 / 513-731-3304.
TFAA-6039-A .. Lower Front Insulator-Round / Obsolete
MILLER OBSOLETE PARTS has 16.
C1TT-6A061-D .. R & L Lower Rear Insulator-Round / Obsolete
GREEN SALES CO. has 66.
C1TT-6068-C .. R & L Upper Rear Insulator-Rectangular / Obsolete
AL WHITE MOTORS in Manchester TN has 1 = 931-728-9700.
No other Ford dealer, no obsolete parts vendor has any.
352 = Upper parts catalog pics at center and right:
Old May 11, 2015 | 04:04 PM
candoo's Avatar
candoo
SO if I can find mounts for a 1965 F100/250 4WD or 1965/66 F350 or 1966 F250 4WD I should be OK with the rear then. Looking at NPD I cannot find a match with the options above. Wonder what the difference is. Closest is a F100 4by4 66 to 67.
Old May 11, 2015 | 04:24 PM
NumberDummy
Dunno if NPD or anyone other repro parts seller has the correct mounts...or not.
Closest is F100 4WD 66 to 67.
Incorrect!
1966 (1966/76) F100 4WD is not the same, has coil spring front suspension. Uses the same F/R mounts as 1965/66 (1965/76) F100/250 2WD
1976 was the last year that Ford offered the F100 with 4WD
For sources, see edited post #4.
Old May 12, 2015 | 08:16 AM
candoo's Avatar
candoo
Many Thanks for clarification. Separated one last night, I am going to make my own rears with purchased rubber locally.
borneo52
Jun 29, 2019 09:05 PM
FordTruckGuy96
1947 and Older Ford Trucks
15
Feb 11, 2017 07:53 PM
Chris 56 f6
May 10, 2014 12:14 AM
Damifiknow
Mar 30, 2014 08:25 PM
Jeff3298
Apr 27, 2008 07:51 AM
