Sponsored by: Real Truck
Whose using what oil??
Old May 8, 2015 | 06:37 PM
haliaeetus70's Avatar
haliaeetus70
I have a 2012 f-250 4x4 crew cab 6.2 liter, I use Mobil 1 in my other vehicles and was thinking the same for the truck? Any issues with that? What's your thought?? Thanks again!!
Old May 8, 2015 | 08:10 PM
TosaFords's Avatar
TosaFords
I use the Motorcraft 5W-20 Full Synthetic and a Motorcraft FL-820S Filter every 7,500 miles in my 6.2L Have since new.
I figure that they guys who designed the engine probably know what to put in it for oil.
I do my oil changes every 7,500 since my mileage is about 95% highway mileage to and from work. If I did a lot more stop and go or heavy towing I'd probably move down to a 5,000 mile interval.
Old May 8, 2015 | 08:23 PM
hodge5's Avatar
hodge5
Motorcraft Semi-synthetic and Hastings oil filters.
Old May 8, 2015 | 08:49 PM
auburngrad's Avatar
auburngrad
Currently running Motorcraft Synthetic blend. But have only done the 1500 mile oil change. I plan on running Red Line Full Synthetic ever 5k miles starting at 5k.
I've run it in my 4.6 Mustang since 15k miles and had perfect compression and no wear at 60k.
I run Red Line in all of our cars.
Old May 9, 2015 | 12:00 AM
KenRebF-250's Avatar
KenRebF-250
We use Mobile 1 5W-20 full synthetic and the Motorcraft filter. Change at 3000 miles or 3 months, whichever comes first. About 90% of the annual mileage is towing relatively heavy, thus the 3000 mile oil change threshold. It might be a bit overkill but oil is relatively cheap.
Old May 9, 2015 | 12:45 PM
Bently_Coop's Avatar
Bently_Coop
I have been using Motorcraft Synthetic blend 5W20 and motorcraft FL820S filter for the last 20k miles of ownership. Don't see any reason to use something more expensive on my V10. Also if running extended intervals check the level. Between 3500 and 5k miles mine seemed to burn a qt.
Old May 9, 2015 | 02:05 PM
Long Haul's Avatar
Long Haul
Will be switching to Amsoil when its due for the next change..
Not sure whats in it now from the dealer I'm guessing Motorcraft maybe..
Old May 9, 2015 | 07:29 PM
fordman19762003's Avatar
fordman19762003
I've been using Motor Craft oil and filters since 2003 and have had really good luck.
Old May 9, 2015 | 07:53 PM
Forddiesel06's Avatar
Forddiesel06
I to have been using motorcraft oil and filters. Seems that the truck likes it.
Old May 9, 2015 | 11:26 PM
mattymax's Avatar
mattymax
What Amsoil product ? Have been thinking of switching over from Mobil 1 to Amsoil but can't justify the added expense. I run Amsoil in all my other things (trans, diffs, t case)
Matt
Old May 10, 2015 | 05:48 AM
JM96F250's Avatar
JM96F250
This, but I do mine ~4000 miles.
Old May 10, 2015 | 07:09 AM
Long Haul's Avatar
Long Haul
Matt
Signature Series 5w20 is what I'm going with..
AMSOIL Signature Series 5W-20 Synthetic Motor Oil
Old May 10, 2015 | 07:22 AM
RangersF250's Avatar
RangersF250
The website says modified and those using E85 are excluded from the extented drain recommendation. Not worth the money from my point of view.
Old May 10, 2015 | 07:53 AM
Long Haul's Avatar
Long Haul
Lots of choices on the market..
Old May 10, 2015 | 01:55 PM
Gage2502's Avatar
Gage2502
I have been using Motorcraft, Pennzoil Platinum, Ultra Platinum, Mobil-1 all in 5w20 Full Synthetic always with a Motorcraft filter.
I change the oil every 4 months or 4k miles.
Has anyone use or try Royal Purple or Valvoline SynPower full Synthetic oil?
...Gage
