Won't Start!!
Old May 8, 2015 | 12:20 AM
kingduvall's Avatar
kingduvall
Do you are any pictures of these scribes on the timing
Old May 8, 2015 | 01:22 AM
genscripter's Avatar
genscripter
Are you getting fuel to your filter head? Crack the line, crank the engine, check the flow.
The line I'm talking about is the front metal line in the image below.
Old May 8, 2015 | 01:30 AM
kingduvall's Avatar
kingduvall
When I push the schrader vavle diesel spits out but I will go crank it loose and let you know
Old May 8, 2015 | 01:35 AM
genscripter
If you got no diesel, or just a dribble, then you have a blockage in your tank, fuel lines, a stuck selector valve, or a malfunctioning lift pump.
If you got a spray of diesel, then your lift pump works. Next crack the exit line from the diesel filter head to the IP. Don't undo the connection to the IP, just crack the line near the diesel filter head. If it sprays out of there, then you are getting fuel to your IP.
If you crack your Injector lines at the injectors, and you get no diesel or just a dribble, then your IP might be malfunctioning or a bad fuel shut-off solenoid. You can check the solenoid by key-on and touch the electrical connector to the spade. Listen for a click.
If the fuel solenoid works, then it could be a stuck metering valve (INSIDE the ip.) This is not recommended for the novice, but you could theoretically open the IP and adjust the spring until it opens. I would recommend you not do that. But I did it once with a sterile latex glove and it worked.
If you are getting lots of fuel to your injectors when cracked, then your injectors could be bad, but I'd still expect the engine to at least start. It'd probably run bad and/or blow lots of white smoke, but it'd run and start.
The glow plugs help, but just for trying to get it started it shouldn't be a required thing. If you replaced them with anything but Motorcraft plugs, you need to get those non-motorcraft ones out NOW. Read the "How to uninstall autolite GP's" article on this forum to learn how to do it without breaking the heads off in the cylinder.
New batteries eh? How are the cables? Rotted or deteriorated? Could be a bum starter, like tecgod said.
If you are getting fuel to the injectors and the juice is flowing, then I don't have any other suggestions. Just for my info, can you take a detailed multi-meter reading of your battery voltage? Not just 12V, but down to one decimal point, like 12.7V.
Old May 8, 2015 | 01:47 AM
kingduvall's Avatar
kingduvall
Thankyou amazing pictures help 1000 times and I cracked all the lines and they're isn't much fuel leaking out of them at all when I crank not like it should be I will test the silinoid on the pump and get back to you hopefully it is just the silinoid I will get back to you on how it goes thanks a million
Old May 8, 2015 | 05:47 AM
bashby's Avatar
bashby
You will only get a small amount of fuel out of the injector lines. If you are getting any,, the FSS is working. White smoke from the tailpipe while cranking it indicates you are getting fuel... Do you see any?
Does your wait to start light come on when you turn the key on? How long does it stay on?
Old May 8, 2015 | 09:20 AM
tecgod13's Avatar
tecgod13
Are you holding the accelerator pedal to the floor while cranking?
If you are cranking it while under the hood, you can manually hold the throttle linkage open. This helps push the air out of the lines quicker. If you don't have the pedal down, its not going to be pushing much for fuel through, maybe like a tiny drop?
Old May 8, 2015 | 10:34 AM
genscripter
before you do anything with the IP, injector lines, injector line seals, etc etc, you MUST check to see if you are getting plenty of fuel to the Diesel Filter Head. Start eliminating variables first before diving into the IP stuff.
Crack the front line on the diesel filter head, crank the engine. Are you getting a geyser of fuel?
Old May 8, 2015 | 11:22 AM
kingduvall's Avatar
kingduvall
The wait to start wasn't coming on until I replaced the glow plug silinoid and now it is also theyre is white smoke when we finally get it to turn over burning my eyes like a MF haha
Old May 8, 2015 | 11:23 AM
kingduvall's Avatar
kingduvall
I will now hold it to the floor while cranking and see if more fuel comes out had no idea that had to be done makes sense tho
Old May 8, 2015 | 12:07 PM
genscripter
I'm trying help, but I can't follow you.
Wait, so just to confirm, you are "finally get it to turn over" means what? It's turning over? So it wasn't turning over before? Do you mean you got it running? Is it running poorly? Is it running for a second then dying? Is it idling? How are you getting white smoke? When you are cranking or while it's running?
Old May 8, 2015 | 12:39 PM
tecgod13's Avatar
tecgod13
If you're getting white smoke, it means you're getting fuel to some of the injectors. Thats a good sign.
I would make sure the batteries are fully charged, and tighten the injector lines up while the batteries are charging. Then let the glow plugs cycle (let the wait to start light go out), then floor the pedal and crank.
Old May 8, 2015 | 03:28 PM
  #28
kingduvall's Avatar
kingduvall
So when I turned it over it was was because of a gas rag on the intake went for 12 to 15 second and blew out white smoke it's goes then slowly dies out
Old May 8, 2015 | 03:29 PM
  #29
kingduvall's Avatar
kingduvall
So when I turned it over it was was because of a gas rag on the intake went for 12 to 15 second and blew out white smoke it's goes then slowly dies out 1
Old May 8, 2015 | 04:54 PM
  #30
bashby's Avatar
bashby
I think your terminology is off. Turning over means the engine is being turned by the starter... same as cranking. These engines wont start if they aren't cranking fast enough. You could try pull start ing it if it is a manual trans. Plugging in the block heater might help also.
