Cranking Compression
Old Mar 13, 2002 | 07:47 PM
71mustang's Avatar
71mustang
What should the cranking compression be on an 89 302.
Thanks
Cody
Old Mar 13, 2002 | 10:35 PM
nitro94's Avatar
nitro94
Highest and lowest readings should be within 20% of each other.
Old Mar 13, 2002 | 11:52 PM
71mustang's Avatar
71mustang
[updated:LAST EDITED ON 14-Mar-02 AT 00:53 AM (EST)]Just got done doing a test, they ranged from 160-170psi. Is this about the psi range they should be in? The engine has 157,000 miles on it.
Cody
Old Mar 14, 2002 | 08:23 PM
garyda's Avatar
garyda
I got a 1989 F150 302 108,000 miles and had it tuned up mechanic tested compression and had 125-130 on mine. Is this still pretty good or can I expect to need an overhaul soon. I'm hoping to get by another year or two. I pull a camper some will this cut down on the life of the engine even more???????
Old Mar 14, 2002 | 08:44 PM
garyda's Avatar
garyda
