I recently pulled out my 1983 F250 with a 7.5l 460 and a Stock Holley 4 barrel. It ran great at first, but now it spits and sputters and will only run for about 40 seconds. I've drained the gas completely out of the tank and changed all the filters and put new gas in with seafoam and it still has the same problem. I checked the choke and everything seemed like it wasn't sticking. I also know my fuel pump is good because when I drained the tank I tested it and it kicked gas out the line great. I'd appreciate any help I could get, thanks.
After it runs for 40 seconds and won't start, pull the air cleaner off and look down the throat of the carb. Push back on the throttle by hand(engine off) and see if you see two strong streams of gas pour into the engine. If you don't, you still have fuel problems.
You would be able to see the streams without the truck on?
Correct, you should have fuel inside your bowl. So that when you actuate your throttle linkage it will pump the gas (strong streams) out of the bowl and down the intake. I would imagine he is trying to see if your fuel pump is failing and only building up enough to pressurize the system to start and then loosing pressure.
Additionally if you have a intermittent problem with the oil pressure or oil pressure sensing switch it will cut power to both fuel pumps, and draining the bowl (30-40 seconds) without refilling it
Yes, your carb works just like a toilet bowl in your house. It stores the fuel in a fuel bowl just like the toilet stores water in the tank. The fuel system is supposed to keep that fuel bowl in the carb full(to a specified height). That amount of fuel in there might be your 40 second run. When you crank the engine the system hot wires the pumps to prime the bowl. That may be all your running on.
It didn't have two strong streams. So now it should be either that oil pressures with or that pump? Thanks both for the help and franklin sorry for asking you a question on that other post haha I just was reading and that guy seemed to have the same problem
I actually found the oil pressure switch on the back center of the motor and tried 'hot wiring it' to the battery and the fuel pump did not come on. So what's next? Inertia switch? Where can I find this?
Not necessarily, you may have a semi stuck float (or filled with gas) or needle, if your bowl isn't filling up it can be multiple things, your venturis can be clogged, a fuel filter can be severely clogged, your fuel pump may be going out.
I would start by removing, your fuel filter, get a container and a rubber hose, run the hose to the from the line you disconnected to the container and try starting it, and see if your even getting flow, if you are, then replace filter with a new one and take hose off at carb and repeat, if you get good flow to that point, then the carb needs to be rebuilt.
Replaced fuel filters already and I get a good flow but it doesn't seem to be constant only after the initial crank. I just pulled out the inertia switch and the white button at the top won't stay flush with the black and when I tip it upside down it free falls until it can no longer move. Should the button be flush with the top of the switch?
Which of the three wholes do I insert the wire to? Sorry for me being such a novice haha
No worries, however I don't have that answer, maybe Franklin2 can help, the pic I found doesn't show much but maybe it might help enough
, I would imagine where the ports "holes" where the two wires are going into, the switch closes the loop with constant pressure, hence why you can jump it, to close the loop
Why don't we back up, and make sure we are on the right track. Also if the truck runs like this, you can take it around the block and at least know it still runs and drives.
See that wire in the diagram below that goes to the starter relay(the starter solenoid on the fender). See if you can find that wire. I think it's on the "i" terminal of the solenoid. In the diagram below it goes to "fusible link T" which is blue, and then goes to a pink/black wire. If you can find this wire, take it off, and make a temp jumper and hook it to the battery + terminal on the battery. The pump should start running. See if the engine will start and run like this. This will make sure your fuel lines, fuel filters, fuel pumps, carb, and everything else is working. We will then know the problem is on the left side of the diagram below.
I figured out how to jump the switch by trial and error and it turned out to be the problem. What is the solution to this? I thank you all for the detailed and constructive help you've given me. You guys seriously saved the day.
