The canister holds the fuel filter. It is corrugated like an air filter. The bottom port is the gozinta, the gravity feed from the fuel tank and the top threaded port is thew high pressure (6-8 psi) gozoutta to the carburetor.
A lot of guys don't even know about the filter.
Not recommended to use a large pair of pliers to remove housing. They do make a small removal wrench similar to an oil filter wrench. If still hard to remove a bit of heat from a heat gun or hair drier near the threads might help. DO NOT USE A TORCH !!! Gasoline is allergic to flames.
You should see the look on people's faces when I use those terms -- gozintas and gozouttas.
