Trailer sway help
Old May 4, 2015 | 09:21 PM
erickz's Avatar
erickz
Trailer sway help
2002 5.4L e150 with Michelin LTX 235/75-15 tires and with the steering dampener installed (would strongly recommend the dampener) towing a 7x18 enclosed trailer with a little british sports car inside. Going down the road we're at 4200 pounds. Towing this with my GMC Envoy was a pleasure till we came to big hills. So we added the e150 as a tow vehicle. There is a lot of trailer sway using the van. Why? It's not fear of death sway but it really is noticeable, hard to drink your coffee sway. Am not using a weight dist hitch - trailer and van look very level. Suggestions? Help!
Thanks
Old May 5, 2015 | 01:18 AM
delgriffith's Avatar
delgriffith
Hate to sound like a broken record but... Check your tires. I think that tire might be an XL rated rather than E load tire. E load tires and 80 PSI in the rears make a big difference. Other stuff, make sure your shocks are good and play with the tongue load. You shouldn't need a weight distribution hitch for that.
Old May 5, 2015 | 01:34 AM
68Mercury250Ranger's Avatar
68Mercury250Ranger
even the 235/75/15 LTs are only 6ply Crange, nothing available heavier in that tire size.
some newer E150 rims could yield a 10ply Erange set of tires.............
Old May 5, 2015 | 07:56 AM
erickz's Avatar
erickz
Would I benefit from a trailer sway control device? And I will check my tire pressures! 41/41 is recommended on the vehicle door sticker - maybe add 10 more pounds in the rear??
Thanks.
Old May 5, 2015 | 12:22 PM
68Mercury250Ranger
read the rating on the tire, run that max psi when you are pulling the trailer. xl tires are 41psi rating .
I've never used any sway control devices. but I have always run 10 ply Erange tires.
*** never run your tires any more than max pressure listed on the side wall, they will also have a max load capacity ***
Old May 5, 2015 | 01:33 PM
vettex2's Avatar
vettex2
yes
Thanks.
worth a try.
you may need more plys though
Old May 5, 2015 | 08:14 PM
redtanrt10's Avatar
redtanrt10
Thanks.
Erick, I tow with a 1500# open trailer and a 3400# car. I have an "equalizer" hitch with their sway control system.
Here in SoCal, and tracking in the desert, I'm regularly going up 2-3k hills and many times hitting mountain and canyon winds in the 30-40 mph range.
My E-150 is very stable. I run Firestone destination tires at the recommended 41 lbs. I'm no expert and never towed before I got this van 5 years ago but all is good. there not cheap but I'm happy and satisfied. good luck, Mike
Equal-i-zer® Hitch - The ?American Original? with 4-Point Sway Control? and Weight Distribution
Old May 5, 2015 | 09:16 PM
Mark T-TB's Avatar
Mark T-TB
Having towed a "little British sports car" around quite a bit on an open trailer with a series of different tow vehicles over the last 20+ years... I hear what you are sayin'.
You should be going arrow straight down the road.
I've been back and forth from SUV (early 4-door Explorer) to a pair of "mid-size" awd GM vans to the 04 Expy and now the E250 for towing.
Some of the basics have already been questioned/covered above. I found surprising variation in tongue and trailer weight capacities of my vehicles.
How sure are you of the 4200#? Most enclosed trailers that I've heard of were close to 3000 # empty?
What is your tonque weight? What is your other cargo weight and where was it?
What is the max tongue weight of your E150?
Good luck with getting squared away, lots of good insight on here
Old May 5, 2015 | 09:32 PM
Harvard's Avatar
Harvard
Where is the caster set? The normal Ford specification is really broad, like about +1.5 to +7.5. I have our E450 set at +5.25 to +5.50 for best highway handling. Less then +4.0 was very troublesome on the highway, as in loose steering and wandering. JMO.
Old May 5, 2015 | 09:39 PM
YoGeorge's Avatar
YoGeorge
The current LTX M/S2's in the P235/75x15XL size have a max pressure rating of 50 lbs, so the 41 is not a universal standard for XL tires. (P rated non XL tires used to have a 35 lb max but they are mostly higher these days as well.) I had 2 prior sets of the M/S's and recall that the orginals from 2002 were 41 lbs max. 2nd set from about 2006 might have been 44 lbs? Now running the M/S2's with 50 lbs max but I don't tow so I run them at ~41 lbs.
I think E load rating is overkill on a 150 and would make for a pretty jarring ride--I would get the alignment set correctly first off. Maybe 235/75x15's in a C range would be a good compromise.
I recall a poster here whose van was scary at freeway speeds and it was an alignment issue that a truck alignment shop finally got right for him.
Good luck,
George
Old May 6, 2015 | 07:59 PM
erickz's Avatar
erickz
Thank you to everyone for the comments. My van tires were under inflated at 38 in the rear and 36 in the front. My fault for not checking them - checked the trailer tires/wheel lugs but not the van (cue Homer Simpson). Trailer empty (trailer spare, battery and wench) comes in at 2350, loaded is 4200 weighed at a CAT scale. Will check tongue weight tomorrow (bought a guage) and will road test with tires at 41front and 50 rear (max pressure on Mich LTX sidewall). I have not unloaded the trailer from the weekend so it should be a good test.
Thank you all again.
Old May 6, 2015 | 08:15 PM
68Mercury250Ranger
you could run them all at 50psi, a good place to start.
Old May 7, 2015 | 01:00 AM
baddad457's Avatar
baddad457
To weigh the tongue weight, weigh the van's rear axle alone on the scale. Then weigh the rear axle again with the trailer hooked up. You may have to weigh the trailer and the rear axle on the scale, then pull the rear axle off the scale then subtract the difference to get the tongue weight. Those weight distributing hitches are often times counter productive as they hang further off the rear of the vehicle, compounding the leverage on the rear of the van. Might do better getting a standard drawbar and try it that way. You can also push the drawbar all the way in the socket, then drill a new hole for the retainer pin to lose even more of the excess leverage. Is the car in the trailer loaded front end first ? Or backed into the trailer ? Should be front end first, but not so far as to put too much weight on the hitch. A new bigger front sway bar on the van will also work wonders in the handling department.
Old May 7, 2015 | 08:23 PM
erickz's Avatar
erickz
We got the guage out and had 650lbs of tongue weight. Car is loaded with the engine going in first. With the tires inflated to 41F 50Rear went down the road much better. The real fix was the sway controller - big help, took the sway right out of it.
Thank you all for your input!
EZ
Old May 7, 2015 | 08:29 PM
68Mercury250Ranger
now you have it dialed in. off to the races
