Modular V10 (6.8l)
Service Engine and #3 coil problem
Old Jul 27, 2003 | 06:05 PM
Clipper508's Avatar
Clipper508
I'm new around this Forum and I know that the plug blowing out problem has been discussed in detail, but I had a problem yesterday that has me puzzled. I have a 2002 F53 - V10 178" wheelbase Class A motorhome.
Took the motorhome out for a test run after installing Gibson Cat-Back exhaust and B&M Transmission temp. gauge. Engine started running rough and then the "Service Engine Soon" light came on.
I pulled into a rest area and connected scanner to OBD connecter. Got code P0353 = #3 coil primary/secondary failure.
Pulled off #3 coil expecting to find plug out, but plug was tight.
Checked coil with ohm meter about 1.5 ohm, same as several others I checked. Reinstalled all coils and turned key on to scan again and clear code. Started engine everything working ok..no light, no missing, no codes! I did notice that the 9/32' hex bolt that holds down the coil was looser than the others. Where the bolt goes through the coil there is a brass insert. Is this a ground for the coil??? or do I need to look further?
There is some great information on this Forum!
Thanks...Ray
Old Jul 28, 2003 | 08:42 PM
Twinbulls's Avatar
Twinbulls
I think its a spacer the coils should move a little,I think??
I swapped out my plugs at 100k miles and tore one of my plug boots and had to get a new coil pak....$ 80 bucks...
I thought that the wires with the conectors are something to look at.
twinbulls
Old Jul 30, 2003 | 09:37 AM
airtractrdrivr's Avatar
airtractrdrivr
Twinbulls:
Why did you have to replace the entire coil pack just because you tore the boot? The boots are available by themselves. I should know, I just replaced all ten of mine!
Old Jul 30, 2003 | 10:04 PM
Twinbulls's Avatar
Twinbulls
Where did you get them????? dealer said ONLY can buy coil pak.
showed me screen with all the parts list on it and I even called a budy who lives in NY and deals in fords. he said they dont sell just the boots. This was last year.
Do you have a part # ?? if so I have a good coil pak that needs a boot..
twinbulls
Old Jul 31, 2003 | 01:31 PM
airtractrdrivr
TwinBulls:
Let me check for you. I had them replaced at my dealer a couple of weeks ago, and I believe the part number is on my service invoice. I will post it this evening.
Old Jul 31, 2003 | 02:24 PM
airtractrdrivr
TwinBulls:
Okay, finally found my invoice. Here is the part number for the spark plug boots: F7TZ-12A402-AA
These were $3.55 a piece, ten costing $35.50. If I am not mistaken, these should be what you need. If I can help you any further, let me know!
Mtthompson777
Dec 31, 2014 05:34 PM
theran1986
3.8 & 4.2L V6
Nov 23, 2014 11:19 AM
otgarza
Jul 6, 2014 06:12 PM
98FordTruck
1997 - 2003 F150
Jan 5, 2011 11:31 AM
mxhowes1
15
Jun 25, 2010 04:59 PM
