Hard Steering / Sticky Steering
Old Jul 20, 2015 | 09:11 AM
TeachNlive4ever's Avatar
TeachNlive4ever
That looks like a ford (thompson?) gear box from a late model dent
Old Jul 20, 2015 | 09:43 AM
TeachNlive4ever
Cracker, you have an automatic column with the shifter linkage removed.
your rag joint looks aweful close to the gear box. It's been a long while I've been in my column but I had the same problem YEARS ago. In the top end of your column under the steering wheel is a cone shaped bushing that sets inside a bearing. As i recall, the bearing is part of the collar. I replaced the cone part, fingered so grease into the bearing. When I was finished, it was better but felt tighter that a frogs butt. I then loosened the cone clamp just above the rag joint, fingered some grease in those bearings and reinstalled the cone clamp just touching the bearings. By doing so, it raised the streering shaft, so much the blinker canceler did't hit the blinker cam. I loosened the 2 bolts under the dash of the column and raised it.
Let us know what you find.
Old Jul 20, 2015 | 10:24 AM
ultraranger's Avatar
ultraranger
Thompson would be a type of power steering pump.
There were Bendix and Saginaw PS gear boxes.
The gear box, from what i can see, looks to be a Saginaw.
Old Jul 20, 2015 | 11:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
That looks like a ford (thompson?) gear box from a late model dent.
No such thing as a Ford/Thompson P/S gear box.
Ford/Thompson P/S Pump: 1965/77 misc. Passenger Cars / 1966/77 F100/250 / 1967/77 F350 / 1969/74 Econoline / 1973/77 Bronco.
Ford/Saginaw P/S Gear Box: 1969 F100/250 2WD & F350 from serial number D96,001 / 1970/79 F100/250 2WD & F350 / 1975/79 Econoline / 1976/79 F100/150 4WD & Bronco.
1977 F250 4WD from serial number Y20,001 (not a High Boy) / 1978/79 F250 4WD / 1979 F350 4WD
This P/S gear box was also used well into the 1990's on misc. Passenger Cars/Trucks/Econolines/SUV's and thru 2002 on Crown Vic/Mercury Grand Marquis.
Old Jul 20, 2015 | 11:06 AM
TeachNlive4ever
Yea, the brain was still a little pickled this AM...
Old Jul 20, 2015 | 11:13 AM
NumberDummy
Is it Bendix or Ford/Saginaw P/S?
It's very EZ to "eyeball" these two gear boxes to tell them apart. See post 14 as I posted both of the parts catalog pics.
Old Jul 21, 2015 | 01:43 AM
Cracker289's Avatar
Cracker289
My shifter stopped working about 10 years ago, the shaft broke away from the rod or something, so when I would go from P to L1 on the column the bracket on the end of the column wouldn't move. So I put myself in a floor shifter and left it at that.
I am going to go through your suggestions and see if I can make this work a little better, it sounds like maybe I just need to loosen the column and the bearing clamp and move it up a half inch or something and take some of the pressure off that joint. Maybe I get some grease up in there to help make it nice and smooth too. Thanks for the tips!
(I assumed this was the pic you saw in my photobucket?)
<a href="http://s1020.photobucket.com/user/crazycracker289/media/F-100/69%20F100%20Brake%20Upgrade/IMG_0326_zpsze7n0ug7.jpg.html" target="_blank"><img src="http://i1020.photobucket.com/albums/af330/crazycracker289/F-100/69%20F100%20Brake%20Upgrade/IMG_0326_zpsze7n0ug7.jpg" border="0" alt="Adjustable proportioning valve photo IMG_0326_zpsze7n0ug7.jpg"/></a>
Old Jul 21, 2015 | 08:55 AM
TeachNlive4ever
No Sir, there is a more clear view of the side of your hydro boost that shows the gear box in the back ground.
This could be the perfect excuse to put a tilt column in
Old Jul 21, 2015 | 09:41 PM
Cracker289's Avatar
Cracker289
Tilt columns are not exactly a dime a dozen though! I have a dent column in my garage up on the shelf, it should be in pretty good shape, I paid $25 for it about 10 years ago...
Old Jul 22, 2015 | 12:27 PM
JEFFFAFA's Avatar
JEFFFAFA
That's how you put tilt in a Bump. I think there is info in Hio's Compilation that show's how to put a Dent tilt column in a Bump.
Old Jul 22, 2015 | 02:49 PM
TeachNlive4ever
I heard him say he had a straight column from a dent. I could have read more into it tho.
I haven't read HIOs thread on it, but with the wiring dodad, I've learned a trick that worked out (for me) to get the wires in the column sleeve...
Old Jul 22, 2015 | 10:02 PM
Cracker289's Avatar
Cracker289
Right, I have a regular straight column from a dent up on my shelf. Tilt columns are not so easy to find!
Old Jul 31, 2015 | 09:48 AM
  #28
TeachNlive4ever
Well, What's the verdict?
Old Aug 3, 2015 | 10:28 PM
  #29
Cracker289's Avatar
Cracker289
I need more time. My month of F-100'ering is already over, with leaf spring replacement, front I-beam replacement, and hydroboost upgrade. I'm working on my Mazda pickup right now and maybe picking up slack on another project after that, I will have to tackle the column in a few months. There's never enough time and never enough money to do everything that needs to be done
Old Aug 4, 2015 | 07:40 AM
  #30
TeachNlive4ever
Yes Sir, I FULLY understand how that is!
Have a good one and may the wind always be at your back.
beersy50
Dec 12, 2023 12:17 PM
leardvr
Apr 19, 2015 12:44 PM
Mayhems67
Feb 16, 2013 08:06 PM
DS02F250
Nov 10, 2002 06:59 PM
dzjammer
Apr 20, 2001 08:47 PM
