F250 and Transmission Coolant System
Yes, all models now have both a air to oil and coolant to oil coolers. Look between the radiator and the A/C condenser (peal back the rubber cover on top of the grill and look down) That is the oil to air cooler. Notice is is quite large. Under the truck, look at the bottom of the radiator. There should be 2 lines going into the radiator. That is the oil to coolant system. Buying a transmission gauge is a good idea.
