np205 married?
Old Jul 27, 2003 | 12:03 PM
lilpig88's Avatar
lilpig88
np205 married?
i've done the searches and can't find any answers. i've got a '76 f150 with an np203 married transfer case. i was going to do the conversion, but last night it wasn't sounding very good. would i be able to find a married np205 and bolt it right on? or are the bolt patterns different between the two. also, if i get a junkyard np205 is there anything i should change beside just the main seals? any other advice?
thanks
Old Jul 27, 2003 | 01:21 PM
sapper145's Avatar
sapper145
np205 married?
I would keep the 203 because the 205 will not just bolt up... and I would save the reduction box off the 203 and run a doubler with a 205. Then you will have 2 low and a 3.97 crawl ratio with all gear driven parts.
Old Jul 27, 2003 | 04:16 PM
lilpig88's Avatar
lilpig88
np205 married?
so if the 205 doesn't just bolt up to my c6, what would have to be done if i were to go that way? (besides customizing it on my own)
Old Jul 27, 2003 | 05:08 PM
sapper145's Avatar
sapper145
np205 married?
I am not sure what your asking???
Do you want to run the 203/205 doubler or just the 205?
For the 203/205 doubler there are many companies and people that mate the 2 together for about $450 and up
The 203/205 doubler is almost the same size as the 203 you have already....you may need new driveshafts but you probally would with the new t-case anyways...
To run just a 205 you would have to find a C6 that had a 205 to begin with an make sure that they have the 31 spline input/output....
Old Jul 27, 2003 | 07:27 PM
lilpig88's Avatar
lilpig88
np205 married?
that's the answer i was looking for. thanks
Old Jul 29, 2003 | 02:19 PM
ecarter50's Avatar
ecarter50
np205 married?
http://mybigbronco.com/info/davids20...205%20Swap.htm
