turn signal
Old 04-24-2015, 06:42 PM
GamalienaireIV's Avatar
GamalienaireIV
GamalienaireIV is offline
turn signal
Recently I noticed all my turn signals work as do the indicator lights. But they don't blink they stay solid. Is this normal for a '77 F-150? It confounds me and surely other people driving behind me.
Old 04-24-2015, 07:43 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Have you changed your "flasher " ? I would start there .
Old 04-24-2015, 07:48 PM
bkaul's Avatar
bkaul
bkaul is offline
Try replacing the flasher.
Old 04-24-2015, 08:31 PM
GamalienaireIV
I must admit I dunno what that is. Is it the fuse?
Old 04-24-2015, 08:50 PM
bkaul's Avatar
bkaul
bkaul is offline
It's what makes the turn signals flash.
turn signal flasher - Bing Images
Has a bimetallic element that heats up as current flows through it, bends and switches off, cools down and bends back, etc. Little round can with a couple pins on it - kind of up behind the headlight switch. There'll be two - one for turn signals and one for hazard lights.
Old 04-24-2015, 11:20 PM
notthemaniusedtobe's Avatar
notthemaniusedtobe
notthemaniusedtobe is offline
The turn signal and hazard flashers are both up behind the dash above the parking brake lever, like bkaul says.
If it helps, the turn-signal is the shorter of the 2 cylindrical silver pods. O'Reilly has it for about $4, just did mine last week when I was replacing the turn signal switch.
Old 04-25-2015, 12:12 AM
GamalienaireIV
Fixed. The relay switch was loose.
cigarxtc
32
04-07-2018 12:00 AM
thepoetsbox
2009 - 2014 F150
10-16-2017 06:16 AM
ducedude
01-07-2014 07:27 AM
Krisverde
08-06-2013 11:06 AM
FatBrian
10-16-2007 05:58 AM
Quick Reply: turn signal
