Ignition problems?
Old Apr 22, 2015 | 02:47 PM
Dillon31's Avatar
Dillon31
Ignition problems?
Hey guys, I just finished restoring my truck a few weeks ago, and I started to take it to a car show. It was running perfect until it started backfiring and sputtering until it died. When I got out and looked under the good I noticed the coil was extremely hot, too hot to even touch. So I wet a rag and put over it to cool it off, and it started right back up, so I immediately started to head back home. But it died every 3 or 4 minutes once I got it started back up. With extremity bad backfire. Any help would be appreciated. As far as voltage goes. I've got 3 volts on my coil, and it goes down the more RPM's I achieve.
Old Apr 22, 2015 | 03:12 PM
Dillon31's Avatar
Dillon31
Also, I've already tried the duras park module and the voltage regulator. And any opinion on replacing the duraspark ignition with an msd system would be appreciated.
Old Apr 23, 2015 | 06:38 AM
Dillon31's Avatar
Dillon31
Bump.........
Old Apr 23, 2015 | 06:45 AM
6.2 V8 power's Avatar
6.2 V8 power
Sounds like you are getting to much voltage to the distributor. Not sure how many volts but less than 13.5
Old Apr 23, 2015 | 08:51 AM
ZarK-eh's Avatar
ZarK-eh
With a resistor wire, coil voltage should be around 8 volts.
Old Apr 23, 2015 | 11:12 AM
79F150400M's Avatar
79F150400M
Could also be the magnetic pickup inside the distributor. Easier to replace the whole distributor in my opinion. Just be comfortable with re-stabbing it and resetting the timing. Covered many times on these boards.
Old Apr 23, 2015 | 07:12 PM
Dillon31's Avatar
Dillon31
Thanks for the replies, but the pickup has already been replaced. Thanks for the help.
79rangerxlt
81
May 13, 2017 07:35 AM
oneofakind97
18
Apr 6, 2015 09:00 PM
Smook
Apr 2, 2014 08:32 PM
gijoe985
21
Jul 22, 2008 08:41 PM
Towbar
Electrical Systems/Wiring
Dec 17, 2001 02:03 PM
