75 390 cutting out
Old Apr 28, 2015 | 01:06 AM
rockittsled's Avatar
rockittsled
https://www.centuryperformance.com/f...nition-Modules
Try this
Old Sep 6, 2017 | 06:16 PM
PSalva72's Avatar
PSalva72
HELLO... PLEASE... I have the same problem in my F250 V8 390 ... PLEASE... did you find the problem... Give me some advise... THANKS A LOT !!!!
Old Sep 7, 2017 | 06:55 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Before you do ANYTHING ELSE, when it won't start after it quits, pull the center wire from the distributor, and put it near ground (engine block or head) and crank it over. Does it have spark?
That's step 1. If you have spark, and it won't start, it's fuel related.
If you do NOT have spark, you'll need to work backwards. Key on, is there voltage between ground and the (+) side of the coil? A test light, or a volt meter is necessary.
Once we have the answers to these questions, we can diagnose it more.
Old Sep 7, 2017 | 06:34 PM
69cj's Avatar
69cj
And if it knocks you on your ***, replace the high tension. Lead.
Old Sep 13, 2017 | 04:37 PM
PSalva72's Avatar
PSalva72
Thanks. New spark plug cables and lead, new spark plugs, carburetor rebuilt... sometimes I can drive for miles running perfect and sometimes just a few blocks. Normally the truck start again right there sometimes takes a few tries... It is driving me crazy !!!!!
Old Sep 13, 2017 | 05:10 PM
MIKES 68 F100's Avatar
MIKES 68 F100
ADD me to this problem list
mine just shuts down when i have secondaries open . take my foot out of it and it's fine.
driving me crazy can't hot rod around !!
Old Sep 14, 2017 | 04:30 PM
PSalva72's Avatar
PSalva72
ideas ???
any improvement ??? I just ordered a new Ignition Switch... running out of ideas...
Old Sep 15, 2017 | 12:31 AM
Destroked 450's Avatar
Destroked 450
Did you check the float level on the rear fuel bowl
Vacuum secondary or double pumper?
Old Sep 15, 2017 | 03:07 PM
PSalva72's Avatar
PSalva72
Hello guys. Thanks for all help and comments. So far so good... replace coil and better timing... 10 degrees... Let's use it all weekend long and see... THANKS !!!!!
Old Sep 17, 2017 | 06:05 PM
MIKES 68 F100
my carb new 3310 (750 vac secondaries) float levels are good .
Saturday i started her up and was going to take a Lowes runs to get some river rock for wife's yard project . I moved the truck to the street then went back in house to get wife , I noticed a fresh puddle under back of truck , hmm ? i crawled under and it's Gas and dripping off my Electric fuel pump . So lowes trip can wait . i pulled truck in garage and grab a flash light , rubber fuel line from tank to pump cracked in multiple places. So i replaced the hose . hopefully this is the source of my problem .
Old Sep 26, 2017 | 02:09 PM
MIKES 68 F100
well I did another lowes trip last weekend , no cutting out . but then again i was loaded down so didn't really open her up .
Old Sep 26, 2017 | 03:25 PM
Destroked 450
You need to watch those trips to Lowes, they will dip into your play money.
Went by our local lumber yard today, needed a few 2 by's, a roll of insulation, some tin and a few pieces of trim to finish up the inside of my small shop.
Left nearly $800 laying on their counter.
There went my Fairlanes new oil pan, again.
Well at lease the shop will be nice inside, won't have any money to work on anything, but the shop will be look good.
Old Sep 26, 2017 | 03:32 PM
  #28
MIKES 68 F100
YUP SWMBO yard projects . $$$ sucking up all my Truck money
I learned F100 doesn't like to have 3,200 lbs of 12x12 pavers in the back .
Old Sep 27, 2017 | 10:59 AM
  #29
Destroked 450
Years ago I had a 73 F-100 with a 428CJ engine, I was having issues with the four barrel secondaries coming in to fast, this was causing a lean condition and the truck would stumble and die out.
The check ball acts as a restricter and the spring controls how fast the secondaries open, that was early on in my learning curve of how to adjust a Holley carb beyond normal adjustments and I'm not sure what fixed it, but I ended up changing out the secondary diaphragm pot for another one I had and the carb went to working properly.
From what you'r describing ether the secondaries are opening to fast or the secondary fuel circuit isn't delivering enough fuel.
dthut
Mar 28, 2017 09:21 PM
seanandrews1
Jun 16, 2013 11:55 PM
Aaron-71
32
Sep 1, 2012 08:22 AM
66flareside
33
Feb 23, 2006 10:50 AM
cowgirl_truckin
Electrical Systems/Wiring
Jun 23, 2003 12:55 AM
