I know they are hard to find but figured I would give it a shot. I am in search of a complete set, front and rear, of full power door panels. Right now I have power windows and locks in front and manual in the rear. Really want to upgrade to power front and rear.
Does anyone have a complete set for sale or know where some are? Color does not matter!
I was always curious if the back door window button was in the same spot as the hole for the window crank. if not, they are close.
Also I think as long as you can find the 4 window power button for the drivers door. and the part of the door panel where the window buttons screws in, you may be able to put it on a door panel with buttons only for the front doors. I can probably take some pics tonight to show the difference.
The hardest part is getting the wiring harness. I believe you will need the cab harness and the driver door harness. iirc the driver door harness goes from the window switches, all the way along the firewall, under the windshield to the passenger door, where there is a plug. A lot of people hack the harness when taking the doors off. What color is your current interior? And do you have remote entry or no, I think that makes a difference in one of the plugs on the cab harness. I had that issue when putting my truck together.
Such a negative Nancy lol I was always curious if the back door window button was in the same spot as the hole for the window crank. if not, they are close. Also I think as long as you can find the 4 window power button for the drivers door. and the part of the door panel where the window buttons screws in, you may be able to put it on a door panel with buttons only for the front doors. I can probably take some pics tonight to show the difference. The hardest part is getting the wiring harness. I believe you will need the cab harness and the driver door harness. iirc the driver door harness goes from the window switches, all the way along the firewall, under the windshield to the passenger door, where there is a plug. A lot of people hack the harness when taking the doors off. What color is your current interior?
My interior is black, which is why i said color dont matter cuz it will get painted anyway, there was a guy on here that had rear panels i was gonna buy at one time but didnt have harness or fronts
if you are planning on painting them I might have some grey stuff that has been sun faded from being out side for a while. the rear doors are owned by my buddy, I could see if he wants to part with the panels. and I ended up with the driver door. I may or may not have a spare cab harness. I would have to do some digging.
