Timing Question
Old Apr 19, 2015 | 05:57 PM
zemus420's Avatar
zemus420
Timing Question
OK I have a 95 F150 5.8L and I've checked my timing today without the S.PLUG in and its reading 6-7. Now I know the base timing is supposed to be at 10 but why is it so low? I have never touched the timing on this engine it runs great. Will adjusting that idle screw throw it off because I messed with it a couple of years back not knowing it was factory set. I would like to try and advance it a bit if possible. What are your thoughts?
Old Apr 19, 2015 | 07:40 PM
Conanski's Avatar
Conanski
Are you the original owner? If the lock bolt isn't tightened down correctly the distributor can creep a little and it will always retard the ignition when it does. So try it at 10deg, then try it at 12, and even go to 14 for kicks, and then back it off a degree when you finally get it to where it pings under load.
Old Apr 19, 2015 | 08:38 PM
zemus420's Avatar
zemus420
Thanks Conanski for the reply. I will adjust tomorrow
tbruz
Jun 8, 2016 03:09 PM
Rod Beauvex
May 5, 2014 02:39 PM
94XLT5.0
Oct 26, 2009 07:06 PM
The67Beast
Jul 7, 2006 08:11 AM
77 steve
Sep 18, 2001 07:31 AM
