2 Speed- 12 volt Blower motor
I just finished installed a VDO PM351 heater motor in my 56 f100 with recirculating heat. After reading these forums- it appeared to be the recommended motor for me. Bad side is that it appears to be a single speed motor instead of the 2 speed motor that's needed. Can you guys steer me in the right direction for a heater motor (2 speed) that doesn't cost an arm and a leg?
contact www.apartswarehouse.com ph. 1-800-409-5211 in Lake Orion .Mi. 48359
LOL, I used the PM354, put it in about 10 years ago. I started noticing my heat wasn't directing anything to the defroster vents. Then I noticed air was coming out the TOP of the heater box! (Supposed to be going in). Sure enough, my fan was spinning backwards... I'd swear it reversed polarity on me, I couldn't be that dumb, could I???
Just reversed the leads and it's working great now. No need to pull it.
I hooked up the 6 volt positive ground motors I had to a 12 v battery w/ jumper wires, turns real fast as you would expect. Then I got a 12 v motor for a 56 and it turned slower and has 2 speeds. I wonder if you couldn't use the 6 v motor or if it would be too fast to move the air or worse burn out??? I was going to try it until I got the correct one.
