sport trac years to avoid?
Old 04-18-2015, 11:42 AM
jswford's Avatar
jswford
jswford is offline
if you have a sport trac how do you like it? i'm thinking of moving from my 93 ranger to a sport trac. i've heard some bad things about the sohc 4.0 in the explorers as far as the timing chains. are there certain years that this was corrected and they used an improved design? are there certain years to avoid with the sport trac? just starting to do my homework now. i'm looking to get something newer before winter.
Old 04-18-2015, 12:37 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,661 Likes on 1,355 Posts
4.0 SOHC motors had some improvement to the tensioner system in '03 or '04. However, they remain a trouble prone engine in that department. Some go well over 200k, some don't. One of the keys is clean oil. So if you find one you like, and it doesn't make a lot of noise and had good records on maintenance, you might be ok. 5 speed automatics have issues as well. Check for firm shifts. A flare between gears isn't the end, but isn't good either. Any other irregularities with the trans spell 4 digit trouble. (as in $x.000)
Rear axle bearings are noted trouble spots so listen for the howl. Front ball joints go a good ways but are a question after 100k.
Gas mileage won't be much different between the 6 and 8.
Old 04-21-2015, 04:46 PM
2007sporttrac's Avatar
2007sporttrac
2007sporttrac is offline
My 2007 4.6 leaks rain through the upper rear brake light. Another owner I know had the same issue- I guess a quick easy fix with a new gasket.
I also had the known issue of seized spark plugs in the head. I got them out with the Lisle extraction tool made for this job .
I currently have an exhaust leak where my headers meet the block. I guess it is a known issue of the bolts breaking. They need to be drilled out at $100 per bolt I was quoted.
The truck has 200 000 miles on it. I would say I am happy with it, and I would buy another- good luck with your purchase.
WingMan71
11-13-2017 07:19 PM
waldreps
04-23-2009 03:04 PM
thirteen
01-20-2009 07:02 PM
88f150*300
05-25-2007 10:45 AM
skud
02-28-2003 09:46 AM
Quick Reply: sport trac years to avoid?
