Installing a 6R140 behind a 3V 6.8L
Hey all,
It sounds like Ford has been mating the newer 6spd 6R140 with the 6.8L in the f650 lineup for a few years. I'm curious if anyone has done this swap in a 250/350 and documented it? here are two links that I've found. This is the sort of thing I'd like to consider someday down the road when a tranny replacement is mandatory in my truck. Looking for inputs, thanks!
https://www.ford-trucks.com/forums/1136965-did-you-hear-about-the-new-6-8l-v10.html
http://news.pickuptrucks.com/2010/07/ford-to-offer-v10-gas-engine-for-mediumduty-chassis-cab-trucks.html
I think it would be great. It seems it should be a fairly straight forward swap I would think. Electrical would most likely be the biggest hurdle but maybe not. Engine elec. items and other items you would think should be close to identical. Hope someone does this soon. It would open many doors for people wanting more in the towing dept.
The new six speed and the older five speed torque shift auto transmission are a much more complicated electrical/Computer system than the old 4r100 set up, the skinny pedal controls the transmission that controls the engine, backwards from the old 4r100. I do believe you'll need some sort of stand alone computer system to control the transmission..... Even then I'm not sure how you make the engine computer happy with not controlling the transmission anymore? Definitely an interesting idea but way over my head in programming it to work.
Im not exactly sure what V10 is in the new F650's but would assume it was the 3V V10, and I'm assuming from the 4r100 comparison you have a 2V V10? If all of my assumptions are correct you would need to swap the engine and transmission and computer's to make it work..... Not impossible but you would be breaking some new ground there.
extra_230s
12-28-2009 09:05 PM
