fuel pump problem
Old Apr 16, 2015 | 06:43 PM
TIRED-ED's Avatar
TIRED-ED
fuel pump problem
This is my first time on . I bought a 1987 f150 5.0 auto that would not start , replaced the computor ,now it will run ,but only from the frame mounted pump . neither tank pump will run , both in tank pumps are new the truck had been sitting a while , I am getting power at the fuel pump relay & at the inertia switch , but no power at in dash tank selector switch .so what am i missing .
Old Apr 16, 2015 | 09:24 PM
TobaccoBarn460's Avatar
TobaccoBarn460
If it's like an '89, it should have a separate circuit, protected by a 10 amp fuse.
Old Apr 16, 2015 | 09:58 PM
subford's Avatar
subford
Well there is no fuse and the power from the inertia switch goes to both the dash tank selector switch and the frame mounted pump.
Sounds like maybe someone did some rewiring.
Old Apr 16, 2015 | 10:00 PM
TobaccoBarn460
Oops, sorry, that would be a diesel.
If you have power out of the inertia switch you should have power to the selector switch.
The power in to the selector switch on the '89 is Red/white striped wire that should be also at the outlet of the inertia switch.
Again that's on an '89.
Old Apr 17, 2015 | 10:53 AM
carguy94's Avatar
carguy94
how did you go about ordering or getting another PCM and were did it come from.
Old Apr 21, 2015 | 09:58 PM
TIRED-ED's Avatar
TIRED-ED
Thanks for the replys , first the 15 amp fuel pump fuse is good. second i had 2 cut wires just outside the fire wall but that was easly fixed , i haven't found anything that has been done to the wiring third 1st comp. thru napa to match #s on original ,that is what is in there now , 2nd comp. salvage with correct hol. interchange .I have looked at several trucks 89 -90 that don't have the frame pump like the one on the 87.and I have not been able to find a copy of the wiring harness for the 87.
Thanks for any help you can give me , Ed
Old Apr 22, 2015 | 07:17 AM
subford's Avatar
subford
The 5.0L did use the 15 amp fuel pump selector fuse. The fuel position in the fuse box was for the 7.5L and 7.3L engines that had the motorized fuel selector valve that you do not have. It was also used for some of the 5.8L and 4.9L engines with the solenoid fuel tank selector valve on the frame.
If you have no power to the selector switch on the dash and the frame pump runs then you have an open wire in the dash area.
Old Apr 22, 2015 | 12:38 PM
TIRED-ED's Avatar
TIRED-ED
Bill Thanks for the reply , the fuel selector switch has a 5" wiring harness attached , 6 wires in 8 holes to match dash wires , the dash has 7 wires , 8 holes
the only wire that is hot here is the seventh that dose not mate to one in the harness , this is one reason i would like to find wiring diagram , none of this wiring looks like it has ever been touched . Thanks Ed
Old Apr 22, 2015 | 05:21 PM
subford's Avatar
subford
I only have the 1986 and 1988 wiring diagrams and I do not know if the 1987 is like one or the other.
I do not understand what you mean by 8 holes. The selector switch should have 6 places that the wires go into.
Demeron
70
Oct 26, 2012 08:11 AM
f-trucker88
Jun 15, 2011 04:24 PM
jablonowski05
Sep 4, 2008 03:08 AM
speedracer54729
Feb 13, 2008 07:11 AM
nd4spd
Feb 21, 2004 09:07 PM
