I will work. While the rear is out of the car you should weld the tubes and and the seams of the mounts on the car. Also look into aftermarket control arms. I wouldn't use the grannetelli arms the sleeves are too Short and cause the bushings to tear apart.
These are the uppers I would use on a street car
http://m.uprproducts.com/mustang-chrome-moly-double-adjustable-upper-control-arm-urethane-bushing.html
Well looking at the 2 tranny x-members I will need to hack the rubber bushing portion of the fox x-member and everything between the upper frame mounts on the f150. Then weld the 2 up. Then for a stock appearance Paint it black bolt it up and done.
I didn't mess with the throttle bracket too much just kinda looked it over and made a few scribe marks.
I already checked those clearances and no problems their just having issues clearing the exhaust manifold and steering gear box shaft. Once I get it set a bit better I am going to build some headers for it myself.
Trav
The tranny will clear dine the location of the tranny won't change but the room needed to run the exhaust system will. There is a relief on either side of the tranny for exhaust pipes. You won't want a single hump x-member because the exhaust will hang about 3 inches off the ground.
Oh I thought you were talking about something else. Is it weird if our stang already has double humps?
Sorry just got off work and my head is somewhere else.
Trav
