91 f250 transmission problem
Old 04-12-2015, 09:07 PM
Jeffc0313's Avatar
Jeffc0313
Jeffc0313 is offline
91 f250 351w 5 spd. 4x4 replaced clutch. slave cyl. And master cyl. It want go into gear when running. Iv bleed it a bunch of times. when turned of it goes in gear fine.
Old 04-14-2015, 02:43 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
A tip when bleeding the clutch. Remove the rubber cup thing that goes into the reservoir. That way it holds more fluid. One pump, bleed, one pump, bleed, etc.
another thing is reverse bleeding. Pump fluid from the bottom up with a brake bleeder pump thing.
The system is so small that it doesn't take much to goof it up.
Old 04-14-2015, 12:52 PM
Mike1's Avatar
Mike1
Mike1 is online now
Sounds like you didn't fill the system before you installed it maybe? Either way it sounds like you still have a ton of air in there. You can try reverse bleeding with a hand held pump or just untamnd said, remove the cap and fill the res all the way and just keep pumping until you get good pedal.
Old 04-14-2015, 02:17 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is online now
I've always had easy success with the bleeder system on these trucks. Pump the pedal a bunch of times if you have to...fast...sometimes you need to pump a bunch to build any pressure if there's air.
You ARE holding the pedal down when cracking the bleeder, right?
Josh Holliday
10-03-2012 11:28 AM
MONAVIERONJON
20
11-18-2010 02:15 PM
stsscott
12-02-2008 05:13 PM
just-n-time
08-07-2008 04:51 PM
Dr_Sin
11-22-2004 01:55 PM
Quick Reply: 91 f250 transmission problem
